Old 12-08-2020, 08:26 PM   #1
Stoker280
Default Head bolt question
I have two different length head bolts for my C8BA 239 flathead V8. I have the torque sequence chart, but nothing telling me what position the long na short ones go in. Is there a specific layout?
Stoker280 is offline   Reply With Quote
Old 12-08-2020, 09:04 PM   #2
tubman
tubman's Avatar
Default Re: Head bolt question
Stock or aftermarket heads? The stock bolts will not work with some aftermarket heads. and it should be obvious with stock heads. The shorter bolts generally go on the bottom of the stock heads. There are a couple of "medium length" holes in the middle of the second row from the bottom that I believe take short bolts. Once you start placing the bolts, what goes where should be obvious.
Old 12-10-2020, 11:51 PM   #3
Karl Wolf
Karl Wolf's Avatar
Put the head flat on the bench, drop the studs in and compare
the heights of the studs.
Karl
Karl Wolf is offline   Reply With Quote
