#41 |
Those look kile KOGEL hi-comp heads, available in two diff comp ratios, cast iron finned with 25% increase in water capacity. Not many made. I've a pair on my 40.
Paul in CT |
#42 |
Yes, these are rare. I seem to recall an issue with them cracking, so I'd get them checked out before throwing them on a motor. It would be cheap insurance.
#43 |
Those are kind of cool - similar in concept the the KR heads.
#44 | |
#45 |
Wow !!!
#46 |
#47 |
Are those from an Oldsmobile?
#48 |
I'm having a hard time seeing the shape of the chamber directly above the piston. It sort of looks domed, but not as domed as a stock chamber. Does anyone else see that, or does it look flat to you?
#49 |
Looks flat to me and I would assume mated to flat top pistons.
#50 |
Grancor combustion chamber
#51 |
Wish I knew how to make the picture bigger.
#52 |
That's a "thumbnail". I "Clicked" on it and it came up to a decent size.
You done good. |
#53 |
mtt
#54 |
#55 |
Thanks, those are the heads that were onmy Bville engine. I wonder where they are now??
#56 |
The Grancor are the better design for flow/power.
#57 |
As you can see the heads have a sligth popup for the 3 3/4 stroke pistons. Also the piston clearance. I made a doming tool to equal the clearance. simple HC.
#58 |
I like those chambers . . . wished I owned a set of those heads! Anybody got a "spare set" that they're not going to use???
#59 |
aren't the Rocket heads kind of a mirror image? That is they have a deeper trough on the exhaust side.
