Old 11-30-2020, 10:28 AM   #41
1931 flamingo
1931 flamingo's Avatar
Default Re: Big Boys Heads
Those look kile KOGEL hi-comp heads, available in two diff comp ratios, cast iron finned with 25% increase in water capacity. Not many made. I've a pair on my 40.
Paul in CT
Old 11-30-2020, 10:39 AM   #42
Tim Ayers
Paul in CT
Yes, these are rare. I seem to recall an issue with them cracking, so I'd get them checked out before throwing them on a motor. It would be cheap insurance.
Tim Ayers is online now   Reply With Quote
Old 11-30-2020, 12:33 PM   #43
Bored&Stroked
Bored&Stroked's Avatar
Those are kind of cool - similar in concept the the KR heads.
Old 11-30-2020, 01:51 PM   #44
petehoovie
petehoovie's Avatar
Old 11-30-2020, 03:54 PM   #45
Cody_1948
Cody_1948's Avatar
Wow !!!
Cody_1948 is offline   Reply With Quote
Old 11-30-2020, 04:22 PM   #46
Ol' Ron
Ol' Ron's Avatar
Now I have to find a picture of the Grancore??? Heads.
Old 11-30-2020, 04:48 PM   #47
tubman
tubman's Avatar
Are those from an Oldsmobile?
Old 11-30-2020, 07:36 PM   #48
Yoyodyne
Yoyodyne's Avatar
I'm having a hard time seeing the shape of the chamber directly above the piston. It sort of looks domed, but not as domed as a stock chamber. Does anyone else see that, or does it look flat to you?
Yoyodyne is offline   Reply With Quote
Old 11-30-2020, 07:58 PM   #49
JSeery
JSeery's Avatar
Looks flat to me and I would assume mated to flat top pistons.
Old 12-01-2020, 01:10 PM   #50
Ol' Ron
Ol' Ron's Avatar
Grancor combustion chamber
Old 12-01-2020, 01:12 PM   #51
Ol' Ron
Ol' Ron's Avatar
Wish I knew how to make the picture bigger.
Old 12-01-2020, 01:25 PM   #52
tubman
tubman's Avatar
That's a "thumbnail". I "Clicked" on it and it came up to a decent size.
You done good.
Old 12-01-2020, 06:39 PM   #53
Ol' Ron
Ol' Ron's Avatar
mtt
Old 12-01-2020, 09:19 PM   #54
Yoyodyne
Yoyodyne's Avatar
Old 12-01-2020, 11:13 PM   #55
Ol' Ron
Ol' Ron's Avatar
Thanks, those are the heads that were onmy Bville engine. I wonder where they are now??
Old 12-02-2020, 06:00 AM   #56
JWL
The Grancor are the better design for flow/power.
JWL is offline   Reply With Quote
Old 12-02-2020, 09:26 AM   #57
Ol' Ron
Ol' Ron's Avatar
As you can see the heads have a sligth popup for the 3 3/4 stroke pistons. Also the piston clearance. I made a doming tool to equal the clearance. simple HC.
Old 12-03-2020, 02:47 PM   #58
Bored&Stroked
I like those chambers . . . wished I owned a set of those heads! Anybody got a "spare set" that they're not going to use???
Old 12-10-2020, 04:07 PM   #59
saltracer
aren't the Rocket heads kind of a mirror image? That is they have a deeper trough on the exhaust side.
saltracer is offline   Reply With Quote
