#61 |
1937 hood latch cam. 78-16628.
Original on right, finished repro in middle, cutout blank on left. I had the cutout blanks laser cut which allows me to hand form and weld up to make the finished part without expensive tooling. |
#62 |
A simple one; yet one I needed recently. now available 11A-16925 1941-51 Ford hood latch dowel spring.
https://thirdgenauto.com/product/194...-dowel-spring/ IMG_9646_InPixio.jpg |
#63 |
These won’t be available until middle of February. But for the 32 guys a perfect reproduction of the transmission cover and dual temp gauge face are coming and both will be very very reasonably priced.
![]() ![]() Sent from my iPhone using Tapatalk |
#64 |
Just back from the polisher:
1941-48 convertible visor arms. 304 stainless and polished. The mounting end is modified to use a "C" clip rather than being riveted as original. I have the springs also available. |
#65 |
Also back from the polisher:
Late 1939-1940 convertible visor arms. 304 stainless and polished. Spring is available. Carpenter had been making these but discontinued them about a year ago. |
#66 |
Late 1935-1936 Roadster/Phaeton windwing brackets. Investment cast 304 stainless and polished. Kit will include hardware as shown. |
#67 |
Excellent work Karl!
#68 |
Karl,
Good show; right down to the correct lock nuts. Will you offer the rubber inserts to retain the glass? |
#69 |
No rubber inserts at this time, Carpenters are slightly off. There is some emerging technology to 3D print elastic materials at a reasonable price... but not affordable to me yet. The lock nuts are a commercial stainless nylock... that happens to look like the original.
#70 |
Michael, you have to make the dual temp gauge faces for the 33/34 gauges. I have 6 of them that need face restoring.
#71 |
I see that you have visor arms, do you have the bracket? I broke mine.
Sent from my SM-G973U using Tapatalk |
#72 | |
Michael I have about a dozen of the 11A cups that go with your 11A dowel and spring if you are interested. 40larry |
#73 |
Hello all
Does anyone know where to find the seal for a 1932 Ford Cabriolet header bow? Drake has quit making them. Realized too late that I should have snagged one. Insight appreciated. |
#74 |
Check with Drake suppliers - they may have some stock. Try Joe’s Antique Auto Parts. Nice folks to deal with .....
Good luck .... |
#75 |
Another simple item that is newly available.
Spring shackle bar for 32-40 fords made exact as original, with the correct shape. ![]() Sent from my iPhone using Tapatalk |
#76 |
Michael, excellent looking shackle bars. Thank you
#77 |
#78 |
The M only appeared on the forged version and only on those supplied by Moore Drop Forgings, which were in a minority of the originals that I've seen, NOS or used.
#79 |
Can we buy directly from you or eBay only?
#80 |
We sell on ebay, but prices are a bit higher as is shipping on there. Best to call direct, or use thirdgenauto.com
