Old 11-19-2020, 11:11 AM   #1
drolston
drolston's Avatar
Default 15" Rims
My brother is looking for a useable set (4 or 5) of stock 15" rims for his '46 coupe in the Reno Nevada area. Speedway has rims with 7" bead width, but at $120 each, beyond the budget. Nothing on Ebay or Third Gen. Any suggestions where to look.
Old 11-19-2020, 11:32 AM   #2
JSeery
JSeery's Avatar
Default Re: 15" Rims
I had my last set custom made, don't remember the price, but it wasn't that bad. And a lot of that was the shipping. There is a shop in LA I think, I could look it up if your interested.
Old 11-19-2020, 12:12 PM   #3
tubman
tubman's Avatar
A factor here is whether he wants to run stock hubcaps or not. If not, wheels should be easy to find, from '49-'51 Mercs and a variety of Ford pickups. If so, he is limited to the venerable '48 Merc wheel, a much smaller selection of Ford pickups, or custom made.
Old 11-19-2020, 12:36 PM   #4
Automotive Stud
Automotive Stud's Avatar
Agreed. If he just needs 15" wheels, a trip to the junkyard would do. Ford pickups and econolines used those into the '90's. If he wants to run the stock type cap, then he needs '46-48 Merc or F1-F100 up until around '56 wheels. They are out there but you'll probably need to post a wanted ad or start shopping swap meets.
Automotive Stud is offline   Reply With Quote
Old 11-19-2020, 01:51 PM   #5
drolston
drolston's Avatar
Thanks, that would be helpful.
Old 11-19-2020, 03:04 PM   #6
skidmarks
skidmarks's Avatar
The pickup 15" wheel for the stock style hub caps are 1956 to 66 and still a lot of them still around for $50 each and less.
I have found them in good shape in junkyards with a junk tire and if you offer to take it with the junk tire the price gets cheaper
skidmarks is offline   Reply With Quote
Old 11-19-2020, 03:58 PM   #7
TJ
TJ's Avatar
X2. There has to be a junk yard in or near Reno/Carson City that has some older Ford pickups.
Old 11-19-2020, 04:22 PM   #8
bobH
Agreed with many of the above comments. For example, I am still storing two 15" wheels that came on a 64 pickup (that I bought new). They take the early hubcap. So, I think there ought to be wheels available in your area. I'd offer mine for free, if we weren't separated by a few thousand miles.
bobH is offline   Reply With Quote
Old 11-19-2020, 04:27 PM   #9
TJ
TJ's Avatar
The original poster put the notice up for his brother who lives in the Reno area. Reno is not that far from Placerville.
Old 11-19-2020, 05:46 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
He wants 7-inches between the beads! Ford didn't make 7-inchers for the early caps. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-19-2020, 05:53 PM   #11
skidmarks
skidmarks's Avatar
He just stated thats what speedway had for $120 but out of his budget. Didnt say they had to be 7" . Sounds more like he would settle for something cheaper.
Old 11-19-2020, 05:58 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
You're ARE correct, Skids! So, we both know that 5-1/2" wide pick-up wheels are all over the place through '66, for the early caps. DD
T5 W/TORQUE TUBE
Old 11-19-2020, 06:48 PM   #13
Ol' Ron
Ol' Ron's Avatar
15" tires are on their way out, like the 14s.
Old 11-19-2020, 07:09 PM   #14
Ggmac
Older jeeps and dodge trucks
Old 11-20-2020, 06:27 AM   #15
PeteVS
PeteVS's Avatar
A while ago, I bought a set of 15" rims. Three of the four have "knubs" for the hub caps while the fourth has spring like fingers riveted on. Who made each of the two types?
Old 11-20-2020, 06:43 AM   #16
skidmarks
skidmarks's Avatar
The one with the springs added, i have had them and they are mid 50s lincoln wheels. Original they were just smooth no clips because they had full size hubcaps
I have had them marked ford, fomoco and KH.
Old 11-20-2020, 08:12 AM   #17
corvette8n
corvette8n's Avatar
https://www.summitracing.com/parts/w...estionsanswers
I bought 5 of these a couple of years back for my ‘41, got them on sale for $59. Each I think.
Coker also has bare wheels also.
https://www.cokertire.com/wheels/smo...r157lm400.html
Old 11-20-2020, 02:52 PM   #18
JSeery
JSeery's Avatar
Well, little more difficult to sort out than I thought! My last purchase was for 2 custom made rims (different offset and width than normal), but had them powder coated and the shipping is in there, so? $376 for the pair, that's $188 each. But again, not sure how much was powder coat and how much was the rims.
Wheelsmith
http://thewheelsmith.net/wheel-catal...vintage-wheels
Old 11-21-2020, 09:41 AM   #19
RB
RB's Avatar
Don't recall the width between the beads, but at least of passing interest the early Jeeps were 5-1/2" bolt pattern with the large center hole as required for 4x4 hub clearance, however they lacked the nubs for hub caps as the hubs protruded too far. I had once purchased a set of (5) NOS rims as mentioned, at an Army surplus outlet. Anyone on the hunt might ck. the 4 wheel drive & surplus outlets.
RB is offline   Reply With Quote
Old 11-21-2020, 10:56 AM   #20
Als48
Another option would be the small Suzukis. I know my 95 Sidekick had 5 on 5 1/2" wheels similar to Jeep.
Al Hook
Als48 is offline   Reply With Quote
