Old 11-10-2020, 02:59 PM   #61
Karl Wescott
Karl Wescott's Avatar
Default Re: NEW products available thread
1937 hood latch cam. 78-16628.
Original on right, finished repro in middle, cutout blank on left.
I had the cutout blanks laser cut which allows me to hand form and weld up to make the finished part without expensive tooling.
Karl Wescott is offline   Reply With Quote
Old 11-23-2020, 09:12 PM   #62
35fordtn
35fordtn's Avatar
A simple one; yet one I needed recently. now available 11A-16925 1941-51 Ford hood latch dowel spring.
https://thirdgenauto.com/product/194...-dowel-spring/
Old 11-25-2020, 04:44 PM   #63
35fordtn
35fordtn's Avatar
These won’t be available until middle of February. But for the 32 guys a perfect reproduction of the transmission cover and dual temp gauge face are coming and both will be very very reasonably priced.
Old 11-25-2020, 05:42 PM   #64
Karl Wescott
Just back from the polisher:
1941-48 convertible visor arms. 304 stainless and polished. The mounting end is modified to use a "C" clip rather than being riveted as original. I have the springs also available.
Old 11-25-2020, 05:45 PM   #65
Karl Wescott
Also back from the polisher:
Late 1939-1940 convertible visor arms. 304 stainless and polished. Spring is available. Carpenter had been making these but discontinued them about a year ago.
Old 11-25-2020, 05:49 PM   #66
Karl Wescott
Yep, the polisher has been busy...
Late 1935-1936 Roadster/Phaeton windwing brackets. Investment cast 304 stainless and polished. Kit will include hardware as shown.
Old 11-25-2020, 06:54 PM   #67
35fordtn
35fordtn's Avatar
Excellent work Karl!
Old 11-25-2020, 07:06 PM   #68
DavidG
DavidG's Avatar
Karl,
Good show; right down to the correct lock nuts. Will you offer the rubber inserts to retain the glass?
Old 11-25-2020, 08:22 PM   #69
Karl Wescott
No rubber inserts at this time, Carpenters are slightly off. There is some emerging technology to 3D print elastic materials at a reasonable price... but not affordable to me yet. The lock nuts are a commercial stainless nylock... that happens to look like the original.
Old 11-25-2020, 09:45 PM   #70
95476
95476's Avatar
Michael, you have to make the dual temp gauge faces for the 33/34 gauges. I have 6 of them that need face restoring.
95476 is offline   Reply With Quote
Old 11-26-2020, 09:14 AM   #71
msstring
I see that you have visor arms, do you have the bracket? I broke mine.
Sent from my SM-G973U using Tapatalk
msstring is offline   Reply With Quote
Old 11-26-2020, 12:44 PM   #72
40larry
Attachment 448274
Michael
I have about a dozen of the 11A cups that go with your 11A dowel and spring if you are interested. 40larry
40larry is offline   Reply With Quote
Old 12-12-2020, 02:58 PM   #73
materguru
Hello all
Does anyone know where to find the seal for a 1932 Ford Cabriolet header bow? Drake has quit making them. Realized too late that I should have snagged one. Insight appreciated.
materguru is offline   Reply With Quote
Old 12-12-2020, 11:22 PM   #74
TomT/Williamsburg
TomT/Williamsburg's Avatar
Check with Drake suppliers - they may have some stock. Try Joe’s Antique Auto Parts. Nice folks to deal with .....
Good luck ....
TomT/Williamsburg is offline   Reply With Quote
Old 12-14-2020, 10:04 PM   #75
35fordtn
35fordtn's Avatar
Another simple item that is newly available.
Spring shackle bar for 32-40 fords made exact as original, with the correct shape.
Old 12-15-2020, 10:42 AM   #76
Zeke3
Zeke3's Avatar
Michael, excellent looking shackle bars. Thank you
Zeke3 is offline   Reply With Quote
Old 12-15-2020, 12:10 PM   #77
40larry
Did you stamp the letter "M" on them like the originals??
40larry
Old 12-15-2020, 12:17 PM   #78
DavidG
DavidG's Avatar
The M only appeared on the forged version and only on those supplied by Moore Drop Forgings, which were in a minority of the originals that I've seen, NOS or used.
Old 12-15-2020, 03:07 PM   #79
maineford
Can we buy directly from you or eBay only?
maineford is offline   Reply With Quote
Old 12-15-2020, 03:13 PM   #80
35fordtn
35fordtn's Avatar
We sell on ebay, but prices are a bit higher as is shipping on there. Best to call direct, or use thirdgenauto.com
