Old 10-25-2020, 05:10 AM   #21
glennpm
glennpm's Avatar
Default Re: 1940 Brake Bleeding
Atmospheric pressure only, that's why whoever is helping doesn't let the pedal up until you close the bleeder and tell them to let up. If not you suck air back into the slave cylinder and/or line when they let up on the pedal.
glennpm is online now   Reply With Quote
Old 10-25-2020, 06:05 AM   #22
51 MERC-CT
51 MERC-CT's Avatar
The original poster has installed 'Speed bleeders' so sucking air back into the system is not a factor.
Old 10-25-2020, 06:23 AM   #23
mike42
mike42's Avatar
Coopman...that Korbel note was funny as I had a guy in Germany who drank that and I always stayed with the Jack.
So....my brake pedal has gone to the floor several times in this long process. Have I created some damage in doing so ?
Drum is going on this morning and I'm going to start the process over again.
Once again.....you fill the master.....pump the pedal.....and turn off the speed bleeder as you refill the master and then turn on the bleeder while I pump the pedal again ? Am I getting that correct ? It's 33º here now and I hope I don't have to start drinking again this morning !!
Thx much..... Mike
mike42 is offline   Reply With Quote
Old 10-25-2020, 07:38 AM   #24
51 MERC-CT
51 MERC-CT's Avatar
Thx much..... Mike
With the Speed bleeder open, pump the pedal 2-3 times, close the bleeder. (do this just once)
You should not have to add brake fluid at this point but check it and add if necessary.
NOW go to opposite side and do the same.
Old 10-25-2020, 08:49 AM   #25
bbrocksr
Originally Posted by JSeery View Post
Ok, I will modify my post. I have never attempted to bleed brakes without the drums on and the way I bleed them it would not work. I put a lot of pressure on the brake pedal, and thus the hydraulics, and it would over power the return springs.
Bleeding brakes without the drums on is pretty risky, Easy to blow your wheel cylinders apart.
Bill
bbrocksr is offline   Reply With Quote
Old 10-25-2020, 09:01 AM   #26
JSeery
JSeery's Avatar
34PKUP: How much pressure is being is being exerted on the wheel cylinder when the bleeder is open and the brake pedal goes to the floor?
You seem to use a different method of bleeding brakes than I do. I have never used speed bleeders or any other aids like that. Been doing brakes from the time I was around 14 and have never had the slightest problem bleeding them. The way I have always done them you apply a lot of foot pressure on the brake pedal, crack the bleed screw, then retighten it. I'm sure there are other ways to go about it, but so far I'll stick with what has worked 100% of the time for me.
Old 10-25-2020, 09:10 AM   #27
rich b
rich b's Avatar
Never having used Speed-bleeders; how do you tell when there are no more air bubbles?
Old 10-25-2020, 09:19 AM   #28
51 MERC-CT
51 MERC-CT's Avatar
By all means, you should continue using whatever method works for you.
'Speed bleeders' are a different animal.
The pedal is depressed while the bleeder is open and without pre-pumping to build up pressure.
Then, after a few pumps and with the pedal in the return position, the bleeder is closed without ever putting pressure on the wheel cylinder.
This is possible because the bleeder has a check valve built in so that on the back stroke no air is allowed to be sucked back into the system, like standard bleeders that have to be closed after each stroke.
Old 10-25-2020, 09:21 AM   #29
51 MERC-CT
51 MERC-CT's Avatar
By looking at the clear drain tube, if you choose to.
Old 10-25-2020, 11:09 AM   #30
19Fordy
19Fordy's Avatar
Mike 42: When you get done bleeding you'll probably want to adjust your brakes for optimum performance.
This thread tells how. I use a 2 x 4 and a bathroom scale as a pedal jack.
Don't forget to also adjust your emergency brake.
https://www.fordbarn.com/forum/showt...40+ford+brakes
Old 10-25-2020, 11:49 AM   #31
Kube
Super Moderator
Kube's Avatar
To reiterate my post #11:
I believe my quote is perhaps the best way I am able to respond...
Old 10-25-2020, 02:27 PM   #32
1931 flamingo
1931 flamingo's Avatar
I think BEFORE I bled the brakes I would adjust them??
Paul in CT
Old 10-25-2020, 02:41 PM   #33
bobH
W O W..... 32 posts, just to bleed f-n brakes? I just finished brakes on a 52 Willys, starting with a completely 'open', 'empty' system. Took about two of those small cans. Never knew I had to know all that is posted here. Whew... I'm exhausted.
bobH is offline   Reply With Quote
Old 10-25-2020, 03:08 PM   #34
V8COOPMAN
V8COOPMAN's Avatar
Funny/Sad/Spot-on! WHEW....I feel kind'a 'whooped' now, too! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-25-2020, 03:14 PM   #35
mike42
mike42's Avatar
Guys I worked on it today and it’s getting better but we have snow coming in northern Michigan the next couple days. Barn not heated so I think this will have wait til Spring. I appreciate all the help and I’ll be back in touch. I saved all this info to refer to in Spring.
Thx.....Mike
Old 10-25-2020, 03:48 PM   #36
19Fordy
19Fordy's Avatar
Mike, Wow, i looked on the map and you are pretty far North. Can you buy a little space heater and get the job done before spring?
I know that's easy for me to say living in FL where its 78 right now.
Any neighbors who could help you?
Old 10-25-2020, 04:34 PM   #37
JSeery
JSeery's Avatar
Can't disagree with that!
Old 10-25-2020, 04:49 PM   #38
mike42
mike42's Avatar
Fordy..... I live on a big Lake up here and only have a couple of neighbors through the Winter season. In fact we have 2 ladies pass away this last month and there’s really no one around. I’ll probably try to work a little bit with the heater I’ve got but it’s pretty cold and snow tonight and morning. I’ll advise.
Thx........Mike
Old 10-25-2020, 06:54 PM   #39
Talkwrench
Talkwrench's Avatar
speedbleeders are one of the best things I ever bought. After reassembling the diff and installing it I pumped the pedal slowly, always slowly and not all the way to the floor on a single circuit system. Cracked the far RHS bleeder open and I heard a rush of air, then a further 5 pumps making sure the clear tube has fluid with no air lock it off over to the other side 5 pumps done! Didn't even worry about the front, nice hard pedal and all done myself, easy.
Old 10-25-2020, 07:40 PM   #40
V8COOPMAN
V8COOPMAN's Avatar
I believe pushing pedal SLOWLY is the 'key' element here. DD
T5 W/TORQUE TUBE
