Hello to ALL....
I have a '36 Ford pickup with an alternator and wanted to replace the Fan Belt with new. I utilized a 7/8" x 1 1/4" long Coupling Nut (with 1/2-13 NC internal thread) and a 1/2-13 NC x 1 1/4" long Hex Head Bolt. I used round cardboard cut-outs under the Coupling Nut and above the Hex Head Bolt to make sure I did not scratch the paint on the intake manifold and bottom of the Alternator. Slowly turning the Hex Head Bolt counter-clockwise put tension on the Fan Belt. Worked perfect so I wanted to share and hope it may help someone else out there. Just curious as to what others out there do for Fan Belt tensioning. Bruce in Ca. Last edited by 1936 ford pickup; 10-19-2020 at 12:40 PM. |
Broom handle. 8^) Jack E/NJ
double post
#4 | |
Same thing over 50 years ago.( Necessity is the mother of invention )
I use a 2x4 with a long diagonal cut on one end. I really like this coupling nut thing and can't wait to copy it. Thank you Bruce!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
We have a '36 PU too, anxious to see yours when done please post pics
Just don't get them so tight that they screw up the generator.
38Bill...
I was in the garage today and my fan belt on the '36 PU had about 1 and 1/8th inch deflection at the half way point of the belt. I snugged it up, knowing about not being too tight, and now it has just shy of an inch maybe 7/8ths inch. It seemed before that my ammeter was bouncing just a wee bit at idle and I was concerned the belt was slipping a tad bit. I was brought up to make sure they were about 1 inch of deflection. Is this too tight now?? |
Where the heck is that thread about cool tools that people made or use?
It's from years ago from what I remember. A V-8'er had grafted a wrench to a prying point to help lift that stubborn genny with a lever applied to it. JM35's super engineered steering and rear hub pullers were in there too! I love your idea because adjusting that belt without getting a little medieval is a challenge. Just recall your deflection at midpoint. That belt don't have to be TIGHT to spin the pumps and power maker. But too tight will jack their shafts up eventually.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 03-11-2021 at 10:01 PM. |
I use a big bar but, I like this better. Thanks for posting.
This is the most elegant tool I've seen, I have it saved as being "1950FordF1"s. (from FTE I suspect) I tried to make one like it but was not successful.
Vergil on here posted the "fulcrum" that bolts onto the WP bolt. Works well but really needs another bolt to keep it from rotating.
'52 F-1, EAB flathead |
Here are a couple of pictures of "Vergil's Tool" :
#13 |
Mr. tubman, Any chance of reposting those photos to make them larger?
Thanks. I found it: https://www.jalopyjournal.com/forum/...n-belt.971007/ Last edited by 19Fordy; 03-12-2021 at 10:39 AM. |
#14 |
Thanks. Sorry for the double post. Last edited by 19Fordy; 03-12-2021 at 10:23 AM. |
#15 |
I did blow them up, but wasn't satisfied with the resolution. Here is what I have. I hope it's satisfactory. (Click the "thumbnails.)
#16 |
Did more searching. Can anyone post a photo or explain how the tool shown in Post #41 works?
https://www.fordbarn.com/forum/showt...t=55015&page=3 Last edited by 19Fordy; 03-12-2021 at 10:36 AM. |
#17 |
Thanks tubman, After I posted , I did a little more searching and found larger version of your follow up.
Thanks for responding. |
#18 |
Now that fulcrum point looks like a good idea too.
Thanks. |
#19 | |
Super Moderator
It appears your fan belt is not correct - too long. Factory fitment had a much smaller "open space" between the generator and chamber cover.
#20 |
Kube I think you are right, as I'm almost out of adjustment the gennie sits kind of high.
This is the belt that was on the truck when I bought it, never gave it much thought. I'll check into it. All I ever did was look for splitting on the 'V' showing time to replace. |
