Old 07-18-2020, 04:21 PM   #21
JSeery
JSeery's Avatar
Default Re: Where does your 53 Ford run?
Originally Posted by Garagekulture13 View Post
I'm a bit nervous to drive the car as is. I'd sure hate to cook that motor.
Not sure that much concern is justified, you have a lot of responses stating that their cars normally run in that area of the gauge. 180 to 190 is a good operating temperature for a flathead. An even higher is not going to hurt anything. Driving it with the coolant actually boiling is not a good idea. With a pressurized system that is probably somewhere around 220.
Old 07-18-2020, 05:56 PM   #22
Scott52
I have a 52 and I tested all the gauges while the cluster was out of the vehicle. Easy to do. Simple remove your sending unit and mount it in a coffee can of water with the sending unit grounded to the car ground and the and an extension wire to the sending unit wire. heat the water up and note where the gauge sits at different temperatures. I used an after market sending unit which may have a different response to the gauge needle at different temperatures compare to the king seeley senders. Until you get confidence in hiow your car runs, having OK temperature right at hot on the gauge gives no warning when it gets too hot.
Scott52 is offline   Reply With Quote
Old 07-18-2020, 06:07 PM   #23
JSeery
JSeery's Avatar
An IR gun is cheap and can resolve all the mystery in a couple of minutes.
Old 07-18-2020, 06:08 PM   #24
JSeery
JSeery's Avatar
Scott, those number look off, I would guess it is the different sensing unit.
Old 07-18-2020, 06:56 PM   #25
joe 1950
joe 1950's Avatar
Bought mine from radiator express this is 5 years ago i think it was @ 265.00 shipped to my door excellent product fit was perfect
joe 1950 is offline   Reply With Quote
Old 07-19-2020, 05:49 AM   #26
Garagekulture13
Garagekulture13's Avatar
I drove the car into work this morning to give one more go and test with a IR gun. I got to work which is a 9 mile drive and she was riding on the tic mark to the right of the wide white bar.
DS center of head 226°
PS center of head 218°
DS thermostat housing 216°
PS thermostat housing 206°
Top of radiator was over 200°
I don't remember exactly because the spring popped off the hood which distracted me and not really what I wanted at 5am. Obviously these numbers will worsen today on the way home with the ambient temps close to 100°.
Sent from my SM-N950U using Tapatalk
Garagekulture13 is offline   Reply With Quote
Old 07-19-2020, 08:34 AM   #27
tubman
tubman's Avatar
Those temperatures sound a bit high. When I first got my '51, I had marginal overheating problems alot like you're seeing. A recored radiator solved that. I would try to correct that before something bad happens. The $265 radiator merntioned above sounds like good insurance. (It cost more than that to recore mine in 1988.)
Old 07-19-2020, 08:25 PM   #28
Garagekulture13
I appreciate the response from everyone. When I got off work tonight I drained the radiator and pulled the thermostats. Radiator appears to be clogged in serval cores and both thermostats were 195s. I believe we may be on to something now.
Old 07-19-2020, 08:51 PM   #29
donald1950
you found it.. get the radiator roded out and 180 stats.......
donald1950 is offline   Reply With Quote
Old 07-19-2020, 09:36 PM   #30
Ford Freak
Originally Posted by donald1950 View Post
you found it.. Get the radiator roded out and 180 stats.......
x 2 !!
Ford Freak is offline   Reply With Quote
Old 07-19-2020, 09:50 PM   #31
JSeery
JSeery's Avatar
Looks like you are finding some issues! I agree, the 195s are a bit high. Something in the 180 to 185 range would be better. Can't bet the IR gun.
Old 07-20-2020, 12:30 PM   #32
Scott52
JSeery, I did mention in my post that the sending unit is after market. (Per the vendor, American made but cheaper than NOS). My message was intended that a calibration of existing sending units, original or aftermarket is not that difficult. I did the same thing with the oil sender and gauge. I just tapped of my 48 Power Wagon oil line and got a couple numbers.
Old 07-20-2020, 01:50 PM   #33
JSeery
JSeery's Avatar
Sounds like your on top of it!
Old 07-21-2020, 06:44 AM   #34
flatford8
flatford8's Avatar
There’s a lot of info here on flushing out the block. Might be a good idea while you have the radiator and stats out. It can only help to keep it cool.....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 07-21-2020, 06:08 PM   #35
Garagekulture13
Inside the heads don't look terrible. I got the old radiator out today and installed the new radiator. Fan hits it. It sits too low.
Old 07-25-2020, 09:49 AM   #36
Automotive Stud
Automotive Stud's Avatar
Hope that blade isn't as close to the tank as it looks...
Automotive Stud is offline   Reply With Quote
Old 07-25-2020, 10:09 AM   #37
Garagekulture13
It was hitting but now it's not. I had to run a shorter belt on the fan. The original top tank did not have any over hang but the new Champion radiator from Jegs does. Also I replaced the thermostats with 180s. I drove the car around town and when I got home I left it running in the driveway while I swept the shop with a heat index of 98°. In the pic you can see the temp. That is as hot as it got. I'd say the problem is solved.
