Old 07-06-2020, 12:53 AM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 69a Block Oil Gallery Crack. Centre bearing
69a block being checked has revealed a crack showing in centre bearing at top side running up to under side of cam bearing area.
Is this able to be recovered by stiching methods or similar ?
Or to source another block?
Appreciate any experience or assistance on this one.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 07-06-2020, 12:56 AM   #2
Brian
Brian's Avatar
Default Re: 69a Block Oil Gallery Crack. Centre bearing
Not nice; a highly stressed area of block...find another one
Brian is online now   Reply With Quote
Old 07-06-2020, 01:00 AM   #3
Phil Gillespie
Brian your comment and advice much appreciated.
Had thought on pinning at ends of crack.
Is this a common area to locate a crack?
Phil NZ
Old 07-06-2020, 03:06 AM   #4
Brian
Brian's Avatar
Phil, I've never seen a crack there, but there's lots I've not seen....
I take it this is the hot engine you recently bought off trademe?
Any cracks through main bearing webs can be considered fatal. sorry!
Old 07-06-2020, 03:29 AM   #5
Phil Gillespie
Yep thats the one.
So a 59a, 69a or an 8BA will take this rotating assembly then.
The search for these begins.
Phil NZ
Old 07-06-2020, 06:20 AM   #6
Brian
Brian's Avatar
What size bore is that block?
I may be able to help.
Old 07-06-2020, 08:24 AM   #7
Tim Ayers
Sorry to hear about this. I agree with Brian comments about it being fatal.
Old 07-06-2020, 04:08 PM   #8
Phil Gillespie
Brian,
Its a 59a and at present its out to 3 5/16 plus 30.
Idea now is to rebuild up the stroker engine less this faulty block.
Phil NZ
Old 07-06-2020, 05:33 PM   #9
Brian
Brian's Avatar
pm sent....
Old 07-06-2020, 08:42 PM   #10
Bored&Stroked
Bored&Stroked's Avatar
Yep . . . sorry to hear about this one, but the kiss of death!
Old 07-06-2020, 09:13 PM   #11
Phil Gillespie
Another piece of garden art it would seem.
Just now to push on and work through it.
Phil NZ
Old 07-07-2020, 04:35 PM   #12
oldford2
oldford2's Avatar
Can you post a picture of the crack? Maybe not the end of the world?
Thanks
John
oldford2 is offline   Reply With Quote
Old 07-07-2020, 05:56 PM   #13
lotsagas4u
Frank Casey to the rescue
lotsagas4u is offline   Reply With Quote
Old 07-07-2020, 07:22 PM   #14
KiWinUS
KiWinUS's Avatar
Hey Gas. Are you paying shipping both ways.
Old 07-07-2020, 08:31 PM   #15
flatford8
flatford8's Avatar
I’ve got a few blocks I swear I’m gonna put right in the middle of the lawn and plant flowers in ‘em. I also would like to see some pics and comments on how this would happen. Sorry to hear about this one......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
flatford8 is online now   Reply With Quote
Old 07-07-2020, 09:16 PM   #16
John R
I've heard reports about cracks in the center main bearing web but I've never actually seen a block with a crack there -- just about everywhere else but not there. Would be nice to see a photo.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 07-07-2020, 10:56 PM   #17
Phil Gillespie
Block is presently with engine machinist. To the naked eye prior to crack testing would be hard pressed to pick it up without the crack detecting process i feel.
Hence need to have block checked both crack wise and pressure tested where it also failed. This has been the good advice passed on from this Forum.
I thank all for input as always.
Phil NZ
Old 07-08-2020, 08:11 PM   #18
Phil Gillespie
Well due to a very very helpful Barn member in NZ I believe I will have a good replacement block to put all this lot back into.
This original engine, just rebuilt and ready to go was far from it.
ie water leaks, crack in block, the quoted flathead Ross pistons upon inspection are dome top which will fit nice with the new Edelbrock heads so there are a couple of plus items here.
Phil NZ
Old 07-08-2020, 09:27 PM   #19
Lawrie
Lawrie's Avatar
Phill, what cc heads are you using, and bore and stroke.
Lawrie
Old 07-08-2020, 11:59 PM   #20
Phil Gillespie
Lawrie
Edelbrock 74cc heads. Bore 3 5/16 plus 30 thou. Stroke: 4.125"
Cam: 5T is being ground to 8CM grind. Will be running a Holley 4 barrel 390cfm on a Speedway Inlet manifold. Scat gear with dome top Ross Pistons.
Phil NZ
