Old 06-20-2020, 07:21 AM   #1
flathead48
Default Pressure test plate
Was wondering the thickness require for a aluminum pressure testing plate., 24 stud block. Thanks, Rick
flathead48 is offline   Reply With Quote
Old 06-20-2020, 10:45 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: Pressure test plate
You could probably get away with 1/4". Use a soft gasket. I use theatrical dance floor material called Marley. I used 1/4" steel for the plate.
Karl
Karl Wolf is offline   Reply With Quote
Old 06-21-2020, 05:38 AM   #3
flathead48
Thanks Karl Wolf for info.
Old 06-21-2020, 09:06 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
I'd make it out of thicker material . . . unless material cost is your big issue. In the end, the coast of the material is small (in my mind) as compared to the time/work put into the end result. I'd probably go with 3/4" myself - but Hey, that is me.
Also, you should take a hole saw and cutout the area for the bore - so you can "see what is going on". If you have time, cut out two 1.5" holes in the valve area. Or, better yet find somebody with a nice big laser or waterjet cutter and cut the center areas out to match a stock head gasket profile.
Old 06-21-2020, 10:04 AM   #5
GOSFAST
GOSFAST's Avatar
If you make it thick enough it can serve as a multi-purpose tool??
We made ours to serve as a pressure-plate tester, a block-plate for finish honing the blocks, and a deck-pinning fixture to pin the heads and gaskets to the blocks (photo below)!
We made it 1.500" thick to be safe.
Thanks, Gary in N.Y.
P.S. When working on any Flatheads it is a "must-have" tool for sure!
File Type: jpg Flathead Ford Block Plate-Multi Purpose.jpg (64.7 KB, 199 views)
GOSFAST is offline   Reply With Quote
Old 06-21-2020, 11:18 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
I believe we finally have a clear-cut, "NO-B/S", definitively-executed, 'manly' winner here! I've often thought that using 1/4" plate for a "home-brew" version was going kind of light. Even though there's not much pressure required to adequately perform the test, it's still pretty easy to deform 1/4" steel plate. If I were so inclined as to make a test plate this late in the game (which I ain't), I'd have to go with 1/2" steel. Pretty hard to distort 1/2" by merely pulling-down with bolts. Plus, 1/2" will take a tapped/threaded hole or two better than a piece of 1/4" will. But, what do I know? NICE frikken' plate, Gary! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-21-2020, 11:56 AM   #7
Russ/40
Russ/40's Avatar
To me, it makes little sense to go through the task of opening the bore, without opening the entire valve and combustion area. Doing so makes a good case for having it at least 1/2" thick steel.
Old 06-21-2020, 12:33 PM   #8
jack orchard
I agree.
if you don't expose the valve seats, how do you check to see if the ports/seats are leaking?
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 06-21-2020, 01:26 PM   #9
flathead48
Thanks guys,I appreciate all the Info and the time to respond
Old 06-21-2020, 01:41 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
I just realized you asked about ALUMINUM. There's absolutely NO WAY I'd consider 1/4" ALUMINUM. 1/2" MIGHT be OK in aluminum. I'd use steel! That aluminum plate isn't cheap, either. DD
T5 W/TORQUE TUBE
Old 06-21-2020, 01:50 PM   #11
flatford8
flatford8's Avatar
I’m with #’s 7&8. If the block turns out to be nothing but a bubble machine.....it’d be nice to see where the bubbles are coming from......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 06-21-2020, 07:46 PM   #12
tubman
tubman's Avatar
I made some aluminum plates for my 8BA's. The head plates were fine, but the 1/4" thick plates I made for rhe water pump outlets leaked badly. I made replacements from 1/4" steel and they worked fine.
Old 06-21-2020, 08:36 PM   #13
flathead48
Thanks again guys, Happy Fathers Day to all you Fathers.
Old 06-22-2020, 07:45 AM   #14
deuce5wndw
deuce5wndw's Avatar
Just got a set from Speedway. Offy brand 3/8 steel plate with rubber on one side. Also two water pump block off plates with all bolts and pressure regulators. I thought $289.00 is cheap.
deuce5wndw is offline   Reply With Quote
Old 06-22-2020, 08:01 AM   #15
Ol' Ron
Ol' Ron's Avatar
I used an old cylinder heads and some hole saws.. Mad it about 40 y3qrs qgo. Can't use it any more because I modified it for another project
