Old 06-01-2020, 04:54 PM   #21
Kube
Super Moderator
Kube's Avatar
Default Re: Rear exit manifolds for flathead 39 Ford
Originally Posted by JayChicago View Post
I have a lot to learn. Why to do you scoff at Drakes statement? Doesn't dual exhaust improve delivered horsepower?
On a stock flathead? Methinks a stock can breathe quite well with a stock exhaust system. Dual exhaust on a stock flathead is for appearance...
Old 06-01-2020, 05:00 PM   #22
51504bat
51504bat's Avatar
Since its an 8ba go with EAB heads.
Old 06-01-2020, 05:02 PM   #23
Chris_AAFord
Originally Posted by drolston View Post
Cubic inches, which if the heads remain the same, brings added compression ration as well.
I bet a turbo or super charge would be the SINGLE best way. A modern part not a back in the day part.
Chris
Chris_AAFord is offline   Reply With Quote
Old 06-01-2020, 06:09 PM   #24
flatford8
flatford8's Avatar
Is it an 8BA?....does a ‘39 exhaust cross over the front like one?...I bought a left manifold from Drake and a right from Shoebox-Central. But it’s a ‘51 with an 8BA. I agree with the dual exhaust is for looks and sound.....and annoying the neighbors when I leave for work in the morning!!!.....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 06-01-2020, 07:10 PM   #25
40 Deluxe
Originally Posted by 5851a View Post
I wonder if back in the day the muffler was a restriction so the police manifold would give you 2 mufflers on the car. Police needed to be quiet. Seems like it would be a lot of engineering, must have made a bit of difference.
Plus the Ford police package included the 255 cu. in. Mercury engine so maybe the factory engineers figured the stock Ford single exhaust was somewhat restrictive.
Old 06-01-2020, 08:02 PM   #26
Ronnieroadster
Ronnieroadster's Avatar
Chris
Chris that would be the single best way however economy may suffer a bit.
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 06-01-2020, 08:09 PM   #27
alanwoodieman
Kube, yes but duals with glasspacks or even straight pipes sound better!!
Old 06-01-2020, 08:45 PM   #28
donald1950
here are one i found on Ebay.....
https://www.ebay.com/itm/1932-1936-F...-/402056410662
donald1950 is offline   Reply With Quote
Old 06-01-2020, 09:10 PM   #29
Chris_AAFord
Originally Posted by donald1950 View Post
Thanks! That looks pretty good!
Old 06-01-2020, 09:30 PM   #30
RalphM
RalphM's Avatar
Chris
Not available back in the day?
File Type: jpg DD7250F6-1AF7-454D-A2BA-20D30732F22B.jpg (9.5 KB, 37 views)
RalphM is offline   Reply With Quote
Old 06-01-2020, 09:38 PM   #31
tubman
tubman's Avatar
Aren't you looking for a rear exit manifold?
Old 06-01-2020, 11:43 PM   #32
V8COOPMAN
V8COOPMAN's Avatar
C'mon guys! Let's be sure of what we're suggesting that folks should purchase. That eBay unit is a "FRONT" exit manifold for a CROSSOVER pipe! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-02-2020, 05:41 AM   #33
Ol' Ron
Ol' Ron's Avatar
Belond equal flow headers. 40% power gain. Always wanted a set. ???????????
Old 06-02-2020, 05:53 AM   #34
Chris_AAFord
Thanks good catch!
Old 06-02-2020, 06:17 AM   #35
KGS
KGS's Avatar
Hi Fordbarn,
Does anyone know of a good exhaust manifold that’s a rear exit that will fit a 39 ford standard? My current manifold dumps in front of the steering box and I’m looking for something that will be easier to run a dual exhaust.
Thanks,
Chris
I have an original Douglas "police" left side manifold used on the '51 and later flatheads. If you can use it, PM me.
Ken
KGS is offline   Reply With Quote
Old 06-02-2020, 07:39 AM   #36
Planojc
Planojc's Avatar
I have Red's headers in my 39 standard with Brockman mellowtone mufflers.
Planojc is offline   Reply With Quote
Old 06-02-2020, 08:28 AM   #37
Chris_AAFord
Would be interesting if we could see a episode of engine masters do a flathead buildup. Maybe we need to start harassing Freiburger.
Old 06-02-2020, 09:30 AM   #38
Gary-UK
Gary-UK's Avatar
Have a look at the French flathead exhaust manifolds. Exit high up and to the rear. https://www.35pickup.com/FrenchFlathead.html
Gary-UK is offline   Reply With Quote
Old 06-02-2020, 09:44 AM   #39
tubman
tubman's Avatar
Belond must have had a much better catalog than J.C. Whitney.
With a 40% increase? I would too.!
Old 06-02-2020, 06:21 PM   #40
40 Deluxe
That would be interesting! Open it up to all flathead engines used in automobiles from, say 1920 to 1954. OEM blocks, cranks and heads only. Otherwise, anything goes! Use the Engine Masters scoring system to give a level playing field to determine the winner. Maybe go by horsepower per cubic inch.
Next, which would be overall horsepower king? 308 Hudson? 346 Cadillac? 359 Packard straight 8? Or a 448 Lincoln V12?
Let the games begin!
