Old 05-25-2020, 02:09 PM   #1
rbertan
rbertan's Avatar
Default No Spark--Follow Up
Thanks to all who responded to my appeal for HELP!!!....
Here is what happened....
First I checked the points with a business card....only had .35 volts at arm...
Next I replaced the condenser with a new one....no change
Checked for spark between the points....none
Checked the spark between coil and ground....manually opening and closing points....no spark
Distributor was a new one out of the box....
Checked pop-out connection....screwed it in only a few turns...no change
So I then decided to take off the dash and check the ignition switch....with the dash plate hanging loose, I turned on the key and checked once more for spark....this time I had all kinds of spark....so upon further investigation I found that the black wire terminal on the rear of the ignition switch was sticking up just enough to make contact with the metal dash board....
THAT was my problem!!! Changed the orientation of the terminal and taped over it to insulate it just as a precaution....put everything back together and surprise….the engine started and ran....
So again MANY THANKS!!! to all of you who wrote with your suggestions on what to check!!!
I attached before and after photos so you could see what YOU have been "working on"...!!
Ralph B.
Columbiana, Ohio
rbertan is offline   Reply With Quote
Old 05-25-2020, 02:15 PM   #2
wmws
Default Re: No Spark--Follow Up
She's a beauty. Congratulations and keep her running.
wmws is offline   Reply With Quote
Old 05-25-2020, 02:35 PM   #3
burner31
burner31's Avatar
Sure looks good, did you did the restoration work yourself?
Keith
Shawnee OK
'31 SW 160-B
Old 05-25-2020, 03:40 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Good sleuthing on the ignition switch.
Old 05-25-2020, 07:03 PM   #5
rbertan
rbertan's Avatar
I did everything myself....most difficult was upholstery and top....paint is Stone Brown urethane single stage....my first Model A restoration...had a lot of fun....
Old 05-25-2020, 07:36 PM   #6
Jacksonlll
Jacksonlll's Avatar
Great job.
Old 05-25-2020, 10:18 PM   #7
Mike Peters
Mike Peters's Avatar
So glad you figured it out and let us know the outcome. Thank you. The before photo looks like this roadster went through a fire? Great restoration!
Mike Peters is offline   Reply With Quote
Old 05-26-2020, 08:06 PM   #8
marty in Ohio
marty in Ohio's Avatar
Ralph, How long did it take to make that "silk purse out of a sow's ear?" She's a beauty. Columbiana, huh? I guess you made a few trips just down the road to Snyder's.
Marty
marty in Ohio is offline   Reply With Quote
Old 05-26-2020, 08:14 PM   #9
Mulletwagon
Mulletwagon's Avatar
Nice troubleshooting ! Thanks for sharing.
Mulletwagon is offline   Reply With Quote
Old 05-26-2020, 10:52 PM   #10
Cory Moffat
Cory Moffat's Avatar
Nice Car.
Cory Moffat is offline   Reply With Quote
Old 05-28-2020, 12:56 PM   #11
rbertan
rbertan's Avatar
It took me 11 months of pretty much working full time on it (I'm retired). I am the "customer of the year" at Snyders for 2019!! (LOL)
