Old 03-14-2020, 07:20 PM   #1
50droptop
Default 1936 trunk handle lock - Need help
The trunk lock on my ‘36 will only turn 3/4 of a turn. I’ve never really cared about it locking as it’s always spent the night in the garage. I will be going to an overnight car show this coming weekend so I wanted to ensure I can lock it up. Any suggestions on how to get it the last 1/4 of a turn?
File Type: jpg 04499397-DF5F-424A-884D-CB6B36226A49.jpg (25.0 KB, 48 views)
File Type: jpg 05E1CB52-CF17-4FF9-9AC7-1A479063ED13.jpg (25.5 KB, 41 views)
50droptop is offline   Reply With Quote
Old 03-14-2020, 07:55 PM   #2
RalphM
RalphM's Avatar
Default Re: 1936 trunk handle lock - Need help
If it worked before I would try putting some powdered graphite in there and work in the key back-and-forth a little bit. It may just be sticky.
RalphM is offline   Reply With Quote
Old 03-14-2020, 08:46 PM   #3
FlatHeadCoupe
FlatHeadCoupe's Avatar
If you have removed the handle at one time, try removing and re-installing 180 degrees rotation to make sure the locking cam/slide bolt aligns with the slot in the lid when turning the key.
FlatHeadCoupe is offline   Reply With Quote
Old 03-14-2020, 09:01 PM   #4
50droptop
I will try that. It does seem like it just hits a stop and doesn’t go any further. Up to that point, it turns quite freely.
Old 03-14-2020, 09:40 PM   #5
paul2748
paul2748's Avatar
I had the same problem on the door of my daily driver. Squirted some wd-40 in it and it worked ok
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-14-2020, 09:52 PM   #6
Randy in ca
Randy in ca's Avatar
Handle should be vertical to be in stock position and will likely fix your problem.
See this thread:
https://www.fordbarn.com/forum/showthread.php?t=200452
Randy in ca is offline   Reply With Quote
Old 03-15-2020, 08:18 AM   #7
50droptop
That was it, handle was in the wrong position. The handle now locks!
Thanks all; I can always count on the barn!
File Type: jpeg C0B13ABC-8AF9-469F-A00B-955160EF3923.jpeg (81.2 KB, 67 views)
Old 03-15-2020, 10:01 PM   #8
Gary Tosel
Gary Tosel's Avatar
Just a comment regarding the trunk handle. My 36 Ford 5W Coupe has the handle in the horizontal position and the lock works fine.
Gary Tosel is offline   Reply With Quote
Old 03-16-2020, 02:58 AM   #9
Randy in ca
So are you saying that they originally could have been factory installed either way or that your's has been modified?
Old 03-16-2020, 04:48 AM   #10
deuce lover
deuce lover's Avatar
Horizontal from factory
Old 03-16-2020, 06:54 AM   #11
Steve in Denver
Steve in Denver's Avatar
Take a look at ebay item #222706284087 factory photo. The handle on the rumble seat lid looks vertical. Not sure why Ford would install it horizontal on the trunk model. As it has to be opened from the side, horizontal is harder to turn.
Steve in Denver is offline   Reply With Quote
Old 03-16-2020, 07:32 AM   #12
deuce lover
Steve,You might be right.I looked in the De Angelis book and they appear to be vertical. I stand corrected.
Old 03-16-2020, 09:36 AM   #13
50droptop
So is it correct to be vertical on both the rumble and trunk models? Is that what we're saying now? This is different from what was stated in the link from post #6.
On my trunk lid, the cutout for the lock tang is facing left (when viewing the car from the rear). On my handle, the lock tang itself is facing up (or down) with the handle in the horizontal position. Therefore, to get the tang to engage in the lid the handle indeed needs to be vertical. Honestly speaking, I could see the handle being vertical on the rumble lid as opening from the side would be easier (in my opinion) with the handle vertical. However in trunk form, it seems it would be easier to open with the handle in horizontal position as you would be opening from the rear. Either way, I'm just glad I was able to get the trunk to now lock.
Old 03-16-2020, 08:23 PM   #14
Steve in Denver
I think it is vertical for both the rumble and trunk models. Take a close look at the attached photos from the Classy Ford V8 book. It looks like it is vertical on this trunk.
And for me, because of the location of the spare tire, it is difficult reach the handle from the back of the car, easier from the side, thus, vertical works best.
Old 03-16-2020, 09:06 PM   #15
50droptop
Makes sense and indisputable photo evidence. I’m convinced.
Old 05-08-2026, 09:44 AM   #16
41merc
I need one with keys for my 36. Thank you
41merc is offline   Reply With Quote
Old 05-08-2026, 11:45 AM   #17
Steve in Denver
I don't have an extra trunk handle. Best to find an original as the repros dont take the same key as the door and ignition.
And some of the guys on the list can rekey it to match what you have.
Steve in Denver
