Old 02-19-2020, 12:24 PM   #21
Aok
Aok's Avatar
Default Re: Head gasket
Originally Posted by Chuck Sea/Tac View Post
Decking or milling changes the cr very little. Check your timing. There is a timing strip available from the dealers that bolt to the front passenger motor mount bolt. Then you can actually use a timing light.
I like the timing strip concept, cost is reasonable, probably don't need it but I like things that make life easier.
Aok is offline   Reply With Quote
Old 02-19-2020, 03:20 PM   #22
bettlesr
bettlesr's Avatar
When I first put the Winfield head, with no counter bore, on my engine, I had a standard head gasket, a solid copper gasket and the another standard gasket. I ran great for quite a while until the head cracked between the two center bolts.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
