Old 01-02-2020, 04:40 AM   #1
Kpar
Kpar's Avatar
Default 33 Rear brakes
Well after a $700.00 bungle with my last (and final) purchase from Mac's I've listened to Barners and decided to repair what I've got. I will use some of the bits they sent me though.
What I'm asking "is there some schematics or measurements on the rear brake track" Mate Lawrie has offered to build these up and machine back to original.
If there are measurements available it would be a lot easer.
Kpar
Kpar is offline   Reply With Quote
Old 01-02-2020, 01:38 PM   #2
cas3
Default Re: 33 Rear brakes
usually there is an area that has not worn, so you have the visual spec of what the height was when new. then you just want to follow that so both sides are straight and level with each other. lawrie can do it in his sleep!
cas3 is online now   Reply With Quote
Old 01-02-2020, 01:49 PM   #3
FlatheadTed
FlatheadTed's Avatar
Keith ,Yes Cas 3 is right ,They are 1" from the spring hanger rivet to the slider ,Not sure if you know about my brake accessory pins in my brake kits ,you just dremal the track flat and select the height you require by rotating the off set pin ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
