Old 11-13-2019, 12:41 PM   #41
DannL
DannL's Avatar
Default Re: What spark plugs are you currently using?
This particular post is no longer relevant.
DannL is offline   Reply With Quote
Old 11-13-2019, 12:52 PM   #42
F.M.
Originally Posted by DannL View Post
Uh oh. I can see this thread has gone to the dogs. Inevitable I suppose. ;-)
Well, What more can be said ??..
F.M. is offline   Reply With Quote
Old 11-13-2019, 03:33 PM   #43
walkerlakeprinter
walkerlakeprinter's Avatar
I never paid any attention until I saw this thread. I have Autolite 3076 and they seem to work just fine. I checked two of them just now and they look just right....not black or burned clean. I see no need to change at this point.
walkerlakeprinter is offline   Reply With Quote
Old 11-13-2019, 03:50 PM   #44
DannL
DannL's Avatar
I think folks may be getting this thread mixed up with the other thread that I posted regarding fouled plugs. That's okay. I'm finding out what preferences there are for spark plugs.
Old 11-13-2019, 04:13 PM   #45
F.M.
And HOW do you figure that ??
Old 11-13-2019, 09:57 PM   #46
DannL
DannL's Avatar
F.M. is such a hoot.
Received some W18's today and took them for a short drive. We need more quality time together before I can form an opinion.
Old 11-14-2019, 09:04 AM   #47
barkleydave
barkleydave's Avatar
W18 pertonix ignition runs great and plugs clean
barkleydave is offline   Reply With Quote
Old 11-14-2019, 09:21 PM   #48
50B
I have used W18 with modern points for more then 40 years.
50B
50B is offline   Reply With Quote
Old 11-16-2019, 12:12 PM   #49
TerryO
TerryO's Avatar
My Tudor has Motorcraft TT10 and my Sport Coupe has Champion C16C in a B engine. Both have been in several years and no issues with either.
TerryO
TerryO is offline   Reply With Quote
Old 11-23-2019, 01:35 PM   #50
DD931
DD931's Avatar
Which is hotter? W16 or W18?
DD931 is offline   Reply With Quote
Old 11-23-2019, 02:29 PM   #51
Purdy Swoft
Purdy Swoft's Avatar
Champion W-18 is hotter than W-16-Y
Old 11-23-2019, 03:12 PM   #52
DD931
DD931's Avatar
Thanks!!
Old 04-19-2022, 03:49 PM   #53
Kinsley
Champion C - 16C What should the gap be?
Kinsley is offline   Reply With Quote
Old 04-19-2022, 04:08 PM   #54
Aretino
Aretino's Avatar
W18
Aretino is offline   Reply With Quote
Old 04-20-2022, 10:44 AM   #55
katy
katy's Avatar
Try .035"
Old 04-23-2022, 10:54 AM   #56
Steves46
Steves46's Avatar
Champion W18.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 04-24-2022, 12:38 AM   #57
G Baese
G Baese's Avatar
W18's, Pertronix coil and non-ethanol 91 octane at 5000' altitude. Much better than the 3076's they replaced.
G Baese is offline   Reply With Quote
Old 04-24-2022, 04:07 AM   #58
ndnchf
ndnchf's Avatar
I had been using Autolite 3076s. But found they were significantly shorter than the original Champion 3Xs. The brass connectors were barely able to reach them, a couple of them were laying on the dustributor body. #3 was so close to the timing rod that it would short to it occasionally. I changed to Champion W18s, which are about the same height as 3Xs - problem solved.
ndnchf is offline   Reply With Quote
Old 04-24-2022, 08:41 AM   #59
Patrick L.
Patrick L.'s Avatar
Autolite 3076s for the 30 years. Hard to find today.
Old 04-24-2022, 09:45 AM   #60
Flathead
Flathead's Avatar
I've had good luck with the Autolite 3076 plugs but I currently run the take a part style Champion C-4 plugs. I consider the C-4 as sort of a poor man's 3-X. Car runs fine with the C-4 plugs.
Flathead is offline   Reply With Quote
