Old 10-08-2019, 05:48 PM   #1
chrs1961815
chrs1961815's Avatar
Default Gear Tooth Pitting
I am in the process of rebuilding a spare transmission. Everything is in very nice shape except the cluster gear which has pitting on almost every tooth on one of the center gears and some pitting on the others. New ones are expensive, and good originals are too, so before I indulge in anything I want to know if I absolutely need it. Since it is a spare trans, it won't be used right away, but my cars are meant to be driven.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-08-2019, 06:41 PM   #2
History
History's Avatar
Default Re: Gear Tooth Pitting
I can't answer for sure but I'd say replace them. This guy does say for sure,,,,,,,https://youtu.be/_ZNVWUrvAcY
This link might be better for the answer. This cat knows his stuff. https://youtu.be/XYVHcLX1qXY
History is offline   Reply With Quote
Old 10-08-2019, 06:42 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
It will make the car move but 2nd will be quite loud
Old 10-08-2019, 07:09 PM   #4
Railcarmover
Junk,not worth the effort, face of the teeth is gone.Look for a good used complete transmission you can find them cheap. Just pull the shift tower and look at the top edge of the gear teeth,if they are straight and true you are good to go
Railcarmover is offline   Reply With Quote
Old 10-08-2019, 07:14 PM   #5
Joe K
Joe K's Avatar
Originally Posted by Railcarmover View Post
Junk
Sawdust in the transmission will quiet it down.
Joe K
Shudda kept the horse.
Old 10-08-2019, 07:19 PM   #6
Railcarmover
Joe K
Out here we use bananas,just cram it full of bananas push'em in with a stick..it'll run quiet till it sells and has a pleasant smell..
Old 10-08-2019, 07:53 PM   #7
SSsssteamer
SSsssteamer's Avatar
Your old gears are junk. Besides having a howl in second, the hard facing is gone from the faces of the teeth and the lines that you see across the faces is also the dotted line that the tooth possibly can break off at. When that happens, you could loose everything. Besides loosing the transmission case, it will ruin your day too. Replace the bad gears with better gears. While you are at it, check out your transmission bearings' wear too. No slop or pits allowed in the bearings either.
SSsssteamer is offline   Reply With Quote
Old 10-08-2019, 07:57 PM   #8
Russ/40
Russ/40's Avatar
If you consider when put into use, the likely life span will be from 5 minutes to 5 years. It will fail and it's going to make a lot of noise. It's just not worth it. Hold off until you can find a better one.
Old 10-08-2019, 08:42 PM   #9
ursus
You have the makings of a real howler and hardly a worthwhile candidate for a "spare".
ursus is online now   Reply With Quote
Old 10-08-2019, 09:00 PM   #10
ryanheacox
ryanheacox's Avatar
That gear also has a lot of wear from clashing the teeth. The first gear section on my old cluster had about that much wear. Found a good used one from a club member, they are out there. I wouldn't reuse it, if I did I'd be worrying about it the entire time I was in 1st and 2nd.
Old 10-08-2019, 09:28 PM   #11
chrs1961815
Looks like I am going to hunt one down. Not a problem because this is just a spare and I am in no hurry. I will inspect the other gears tomorrow to see if the teeth are just as badly worn. I was going to replace the bearings anyways along with the shafts.
Old 10-09-2019, 09:37 AM   #12
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I may be able to help you out. I have been approached by a local lady to assist liquidating some of her late husband's stuff. I saw a large selection of Model-A gears on a shelf. There may be something there that is useable if you are not wanting to purchase new gears.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-09-2019, 10:47 AM   #13
Jim Brierley
That kind of pitting is caused by wear, the teeth have gone thru the hardening. I doubt that it will fail, but will likely be noisy.
Old 10-09-2019, 07:36 PM   #14
Brian in Wheeling
Brian in Wheeling's Avatar
Junk in my opinion. why put it back in? Its wore out. So, i put it back and now have a rebuilt trans? Well i took it apart and put it back together...doesnt that mean its rebuilt?
Brian W.
Brian in Wheeling is offline   Reply With Quote
Old 10-09-2019, 08:45 PM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
If Brent doesn't have one, then call Bert's. 800-321-1931
Save the old one to make a table lamp for an end table in your living room.
Your wife will love it, and it makes a good conversation piece.
Old 10-09-2019, 09:43 PM   #16
chrs1961815
Never thought of it like that... but I was going to keep it anyways!
Old 10-10-2019, 08:16 AM   #17
DD931
DD931's Avatar
There is an apparently nice cluster gear for sale for an attractive price on the "Swap Meet"!!!!
DD931 is offline   Reply With Quote
