Old 08-27-2019, 10:53 AM   #1
deuce_roadster
deuce_roadster's Avatar
Default Risk of using old (over 10 years) tires
I just added an album with 4 pictures that should make you think about running old tires, whether bias ply or radial. A friend of mine lost a 40 coupe due to a LR blowout taking out the filler neck and starting a fire. This was on the way to a rod run with a full tank of gas.
Look at pictures in my album MISC.
[IMG][/IMG]
Old 08-27-2019, 12:30 PM   #2
supereal
supereal's Avatar
Default Re: Risk of using old (over 10 years) tires
Tires don't need to show excess tread wear to be dangerous. Sun exposure and the natural ozone in the air degrades the rubber. Unless the tires are shielded in the garage, or covered outside when stored, ten years is well past due for replacement. Even then they are on borrowed time.
supereal is offline   Reply With Quote
Old 08-27-2019, 12:51 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Odds are that this may not happen to any body else but it sure gets one to thinking about adding a substantial shield ahead of the filler pipe to possibly prevent this from happening, bad tire or not.
Old 08-27-2019, 12:59 PM   #4
34pickup
34pickup's Avatar
Out of the 8 cars and trucks I have, only one has tires newer than 10 years. I will take my chances.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 08-27-2019, 01:10 PM   #5
Automotive Stud
Automotive Stud's Avatar
Agreed, I've been thinking of fabbing up a shield like a '46-48 mud guard and attaching it to the fender brace and body behind the driver rear on my '40 after hearing about this.
Automotive Stud is offline   Reply With Quote
Old 08-27-2019, 01:10 PM   #6
Automotive Stud
Agreed. I'd go broke buying tires every ten years.
Old 08-27-2019, 01:56 PM   #7
adileo
adileo's Avatar
I had taken my 39 for a wheel alignment and tire balance. A good mechanic read the numbers on my tires (which were on the car when purchased) told me they were out of round and 13 years old.
Ordered new set from tire rack for $320 bucks. I do feel safer at 65 on highway.
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 08-27-2019, 02:13 PM   #8
Shu47
Shu47's Avatar
deuce roadster, Not say that running old tire is a good idea but I am a fact based kind person. How old were his tires and what actually caused the blowout? Did he hit something, did the thread separate from the tire, what actually created the blowout?
Shu47 is offline   Reply With Quote
Old 08-27-2019, 03:20 PM   #9
Krylon32
Recently bought a 40 standard coupe that was built a number of years ago. I knew even though the tires looked new they had some age on them. When my guy took the old tires and wheels and new tires to the tire shop they wondered why we were replacing them. He looked at the date on the old tires and they were dated 2000. I then checked my delivery which had 11 year old tires and my 3 window which had 13 year old tires. They are all being replaced.
Krylon32 is offline   Reply With Quote
Old 08-27-2019, 03:44 PM   #10
deuce_roadster
Shu47, when a tire blows out on the open road and burns up, I don't know how you would determine what caused it. What he said was that he was driving along on a smooth road and it let go. All he would admit to was it was over 10 years old and maybe closer to 20. Was running 32 lbs in each tire.
Another friend of mine recently had the RR tire on his 33 3w have half the tread separate from the casing (stayed attached at one end) and it beat the s**t out of his rear fender. This tire was 18 years old.
He ordered a new set from Diamondback.
Old 08-27-2019, 03:57 PM   #11
Ranchero50
My '68 Fairlane still has the tires that I put in '91. Yeah, I don't run them above 35 or so and they still look like new (been inside all those years)...
Ranchero50 is offline   Reply With Quote
Old 08-27-2019, 04:23 PM   #12
5851a
We all have insurance, this is just another 50 a year over 10 for new tires. With todays texting drivers I would prefer to not have to pull off the road for anything. JMO
5851a is offline   Reply With Quote
Old 08-27-2019, 04:47 PM   #13
Mart
Mart's Avatar
My tyres are quite old. It is very important to be alert and listening for any changes in noise as the car is driving along. Any sudden increase in noise level can mean a tyre is about to blow. It happened to me once in an old BMW I was able to stop and change the wheel. I heard a sudden noise increase in my Valiant and stopped. All was ok, it was just a change in road surface. Better safe than sorry.
Old 08-27-2019, 04:55 PM   #14
RalphM
RalphM's Avatar
I run old tires, best solution I have is to not run any fenders, there’s nothing to hit if it blows!
File Type: jpg 743143D2-91F2-4A2F-979A-185AEE668750.jpg (82.3 KB, 24 views)
RalphM is offline   Reply With Quote
Old 08-27-2019, 04:55 PM   #15
Ken/Alabama
Ken/Alabama's Avatar
Just this month at the Tri-Five nationals in Bowling Green Ky a Gentleman lost his life after the 55 Chevy he was driving wound up on its roof on I-65 tossing him from the car. Cause was determined to be a blowout from outdated tires. So sad.
Old 08-27-2019, 05:08 PM   #16
RalphM
RalphM's Avatar
But I am smart enough to have seatbelts!
Old 08-27-2019, 05:30 PM   #17
Kurt in NJ
Kurt in NJ's Avatar
In the early 80s we got a 46 ton and half truck, it had original tires on it, bald to the cord, went to the local recapper, he took a look at the tires, saw "s4"-- nylon cord, said no problem, full core values, they got recapped and sold, after using the truck for 10 years we sold it to a guy moving a airplane coast to coast, he made it in 4 days, I don't think he drove slow
So it would be interesting to know--- were they tubeless mounted on original rims???
Old 08-27-2019, 05:30 PM   #18
Jack E/NJ
Jack E/NJ's Avatar
Mart>>>My tyres are quite old. It is very important to be alert and listening for any changes in noise>>>
This. Even a sidewall bubble on a bias or radial gives a warning. And can happen on a new tire on a curb hit. Don't get too comfy with brand new tires either.
Jack E/NJ
Old 08-27-2019, 08:04 PM   #19
hotcoupe
hotcoupe's Avatar
Kurt in NJ is offline Report Post
I think this is the most important question.
Tom
hotcoupe is offline   Reply With Quote
Old 08-27-2019, 08:11 PM   #20
paul2748
paul2748's Avatar
I can't believe those guys that say I'll take my chances.
48 Ford Conv
56 Tbird
54 Ford Victoria
