Old 07-30-2019, 07:37 PM   #21
Ritzy1
Ritzy1's Avatar
Default Re: How hot is too hot?
Thanks again for all the feedback. As many of you know, these carbs come with .045 jets. Since I'm a rookie with flatheads, I consumed Vern Tardel's book How to Rebuild and Modify Ford Flathead V-8 Engines. That became my bible. In there, he recommended starting with .041 jets with a dual carb setup at sea level, which is what I did. When I first started it up, it went way hot, so I changed back to the .045 jets. After some tuning by John Freeman at Freeman's Garage (authorized Stromberg distributor), we decided to put the .041s back in. There may indeed be a happy medium (.043). Again, it's only been on the road for two weeks, so I'm still sorting. I do love how it cruises along effortlessly on a flat highway at low RPM in 5th, but I realize I've got to raise the RPM up for when I come to a hill. So far, I've just been dropping it down a gear if it starts to lug. I think I've yet to get it above 3,500 RPM in any gear.
40cpe, I'll test your equation when I take it for a spin later this week, and let you know the result.
Ritzy1 is offline   Reply With Quote
Old 07-30-2019, 09:33 PM   #22
qmdv
qmdv's Avatar
Originally Posted by flatjack9 View Post
i'm running about 2300 rpm at 70 mph. Get around 20 mpg on the highway.
I have no overheating problem cus I just got the engine fired up. But in a 32 Roadster with 281cu in 59AB and 3.27 rear end gears I calculate 2700 RPM at 70. Is that to many RPMs. Tires are 28 1/2 diameter
qmdv is offline   Reply With Quote
Old 07-30-2019, 09:44 PM   #23
JSeery
JSeery's Avatar
Just depends on the rpm range you are comfortable with. I like to keep the engine in a bit higher rpm range myself, other do not. It also depends on the cam you are running. I like a longer duration higher lift cam, there for the higher rpm range.
Old 07-31-2019, 09:22 AM   #24
big job
big job's Avatar
Thats why Model Ts have no temp gauge !!! LOL
big job is offline   Reply With Quote
Old 07-31-2019, 11:41 AM   #25
Ol' Ron
Ol' Ron's Avatar
I don't think it's too hot, YET! like tosee cruise RPM around 2400 with a Max#1 cam. Enjoy the ride.
Old 07-31-2019, 12:48 PM   #26
Sid
Sid's Avatar
Running that trans./rear end gearing you may be lugging. I'm running the same overdrive trans. with 3.25 gearing and 235/70/15 tires and at 65ish in 5th gear i'm at about 1900 +- rpm and I almost feel 3.40 gears are possibly more suited. With your gearing you may consider running in 4th gear. I am running the V8 Camaro 5 speed that has the 2.95 first gear so you may have to consider your first gear ratio for your decisions. As far as a final rpm probably 2100 to 2500 rpm is a good safe range. Some folks may dis agree.
Sid is offline   Reply With Quote
Old 07-31-2019, 06:41 PM   #27
Ritzy1
Ritzy1's Avatar
Interesting to see you recommending 2,400, Ron. Putting this thing together, my mind was thinking low RPM at highway speeds like a modern car (1,800-2,200).
I was also surprised to see flatjack9 getting 20 MPG running 2,300 RPM.
This is how I learn. Great resources here! Thank you!
Tomorrow night when I get home I'll see what the RPM is in 4th @ 70 MPH.
Old 07-31-2019, 10:11 PM   #28
Ol' Ron
Ol' Ron's Avatar
I also think the water pumps have allot to do with the temp. along with the radiator and condition of the block water jackets. Most modern radiators have a 7 LB cap. Yet some engines overheat. Flatheads do that????
Old 07-31-2019, 11:05 PM   #29
Tinker
Tinker's Avatar
Just to keep this in this thread and not start another.
rpms.
Idle about 1000-1200
Running/cruising 2000 -2400
Max on a hop up 3,500-4,000
Old 07-31-2019, 11:51 PM   #30
Liam
Do not pay attention until it starts to boil.
Liam is offline   Reply With Quote
Old 08-01-2019, 04:16 AM   #31
tubman
tubman's Avatar
rpms.
This seems high. What cam are you running?
Old 08-01-2019, 09:48 AM   #32
JSeery
JSeery's Avatar
rpms.
I like a fast idle, but that's way beyond a fast idle! Your halfway through the advance curve.
Old 08-01-2019, 11:31 AM   #33
flatjack9
flatjack9's Avatar
I idle at 800 with my 39. I like the speed up a little because of the cam and the crank mounted fan.
Old 08-01-2019, 02:40 PM   #34
Ritzy1
Ritzy1's Avatar
Mine seems to idle all over the place. It certainly doesn't like to idle when it's cold. If I try to hit the road too fast, it'll die when I come to a stop. Once it's warmed up it can range from 750-900. I need to check to make sure the throttle's not sticking somewhere.
Old 08-01-2019, 02:52 PM   #35
Charlie Stephens
Is your temperature gauge accurate? You can boil a pot of water at sea level and it will be 212 degrees.
Charlie Stephens
Old 08-01-2019, 03:31 PM   #36
Ritzy1
Ritzy1's Avatar
Charlie Stephens
Haven't tested it Charlie, but I also don't feel the need to. It's brand new Dakota Digital stuff, and when the fan kicks on using a separate thermostat control, the gauge is reading 185.
Old 08-01-2019, 08:15 PM   #37
Ritzy1
Ritzy1's Avatar
Originally Posted by 40cpe View Post
Assuming 27" rear tires, the RPM calculator says that Ritzy1 should be turning about 2378rpm at 70 in 4th gear (1:1 ratio). That would be an option to check the operation and temperature at normal RPMs.
Yup, 2,380 RPM @ 70 MPH in 4th. Right on. It did tick up to 205 on both heads again, but dropped fairly quickly when I slowed a bit. May need to fatten it up.
Old 08-01-2019, 09:21 PM   #38
qmdv
qmdv's Avatar
What is your rear end ratio
Old 08-01-2019, 09:31 PM   #39
Tinker
Tinker's Avatar
I probably idle at about 600-700, I'm guessing... Don't have a rpm on the car but have a rpm tester, never really tested, just by ear (guess I'll test it, i tune with vacuum). I do have a reground cam, it's a bit lumpy. Could use a bit more idle so it doesn't load up idling. I do run a vacuum gauge in my 36 full time, no rpm.
It was just a topic suggestion I made for discussion. Not what I run.
Old 08-01-2019, 10:10 PM   #40
Tinker
Tinker's Avatar
Have you put a vacuum gauge on the car? How are the plug reads? Sounds to be too lean from that description. Possible float or fuel pressure. Just from your post above.
