Old 05-15-2019, 12:53 PM   #101
marko39
Default Re: First Flathead Build
Originally Posted by kegmon View Post
This probably isn't the best way but it worked for me. Pry up the spring from the bottom and see if you can't get the 2 little keepers on the valve stem bottom off. If you can, then the valve should just pull out from the top. A little of the aforementioned acetone/trans fluid on the valve guides will help. I was then able to pop the springs out (wear eye protection). After that I tapped the valve guides down and out from the top using the right sized socket and extension.
That method works unless the valve is stuck open and has too much tension on the spring.still, these valves are easier to remove than the mushrooms.
marko39 is online now   Reply With Quote
Old 05-22-2019, 06:02 AM   #102
sharp21
These are mushroom valves. I’m still struggling with this. Am going to break down and buy the clip removal tool today. Will prolly be two weeks before it arrives...
sharp21 is offline   Reply With Quote
Old 05-22-2019, 10:47 AM   #103
RalphM
RalphM's Avatar
That cone shaped piece is not part of the valve, raise it up and the split keeper will fall out of place( may need a little help).
RalphM is offline   Reply With Quote
Old 05-22-2019, 10:55 AM   #104
JSeery
JSeery's Avatar
"These are mushroom valves."
Those are not mushroom valves, the cup part (6534) is just part of the rotator.
Old 05-22-2019, 09:56 PM   #105
sharp21
So I need to slide that cup upwards? I’ll give that a try tomorrow
Old 05-23-2019, 06:17 AM   #106
sharp21
Small wins.
Got the first one out. I leveled up on the fork and gave it a smack with the hammer. That got the keeper to move and the retainers just fell off.
From there I levered out the spring aaaaand.... stuck again!
That’s the valve guide from the top. I tried getting on it with the hammer and an extension but no dice.
That’s it in the inside. I can easily get the fork on it now but as it fully engages there is nothing to lever against. Can’t get it to budge.
I’ve soaked it with 50/50 and am off to work. Will try again tonight
Old 05-23-2019, 07:22 AM   #107
JSeery
JSeery's Avatar
Your getting a lesson on how easy some flatheads can be to disassemble!!!!!
A large diameter brass or aluminum rod makes a good drive to get the guides out.
Old 05-23-2019, 07:23 AM   #108
marko39
you can now use a crowbar with a block of wood to pry valve out. if you are lucky you wont bend it but i would figure on using new valves anyway.
Old 05-23-2019, 08:42 AM   #109
GOSFAST
GOSFAST's Avatar
Just get a "conventional" valve spring compressor, those rotators and locks will come right out.
This is how we install all the valves during the reassembly, with a spring compressor. Ours is air-operated but a hand one will get it done also!
Thanks, Gary in N.Y.
P.S. Here's a shot (again) of the compressor at work, makes life easy.
File Type: jpg Flathead Air-Operated Spring Compressor.JPG (78.3 KB, 80 views)
File Type: jpg Flathead Air-Operated Spring Removal.JPG (77.3 KB, 76 views)
GOSFAST is offline   Reply With Quote
Old 05-23-2019, 09:02 AM   #110
19Fordy
19Fordy's Avatar
After you remove the lifters, drill 1/8 inch holes in the lifter bores to make adjustment easy.
Would be nice if those are original Johnson adjustable lifters. Don't throw them away.
Old 05-23-2019, 10:35 AM   #111
RalphM
RalphM's Avatar
And be sure to drill the holes as low as possible so a punch, or drill rod will center in the slot on lifter when adjusting your valves. You’ll see when you finally get one of the lifters out.
Old 05-27-2019, 06:52 AM   #112
sharp21
I’m going to circle back with you guys when I get to this stage. I’m having trouble getting the guides out still...
I’ve got them soaking and give em a whack with a socket from the top every time I go by, but no joy yet
Old 05-27-2019, 08:22 AM   #113
JSeery
JSeery's Avatar
I think a brass or aluminum rod would be a better driver than a socket.
Old 05-27-2019, 04:28 PM   #114
sharp21
Trouble is finding one. I’ve looked at my usual stops and they don’t carry them.
I’ve got a long socket that I plan on beating to death. Good news is that things are starting to move!
Old 05-27-2019, 05:32 PM   #115
JSeery
JSeery's Avatar
LOL. I collect up different size and length rods to use. We have a surplus store that handles stock metal that is a good source.
Old 05-28-2019, 05:59 AM   #116
tubman
tubman's Avatar
For stuff like this, I use a place called "ONLINEMETALS.COM". They have "samples" of just about anything you might want in the $3-$10 range. Be careful to keep your orders small enough so you can specify USPS shipping, or the freight charges will kill you.
Old 05-28-2019, 12:33 PM   #117
sharp21
Great tip!
Old 05-28-2019, 12:59 PM   #118
rotorwrench
rotorwrench's Avatar
I use the same guide driver as I use on my Harley 45 flathead guides. It uses 11/32" ID guides too. This is a link to the KD 812 set that has an 11/32" driver size. https://www.ebay.com/itm/K-D-Tools-N...UAAOSws7xc0kQi
The KD 918 valve puller would likely work as well but I use it to pull the complete assemblies after I yank the horse shoe clips out.https://www.ebay.com/itm/VINTAGE-FOR...EAAOSwL9hc5ciz
Old 06-02-2019, 08:40 AM   #119
sharp21
I see what you mean now. I had one complete assembly that pulled out from the top. Next time I’ll get the clip removal tool and do it that way.
Old 06-02-2019, 08:42 AM   #120
sharp21
Circling back! Finished the valves yesterday.
And the lifters this morning
Now where am I supposed to drill these holes?
Don’t forget to clean up your tools when finished for the day!
