Old 05-09-2019, 11:57 AM   #1
nailbender
Default No oil pressure [8BA]
This on new rebuild, done at a shop.[this shop is OK done other work for me] Started with electric gauge checked with mech. no pressure. pulled the gauge only drips from the tube. Changed oil again, same. Pulled the pan and pump [looks new as the invoice said]. The engine fired right up and sounds good. With the pan off I can see assemble lube here and there. Put air up the pump hole via rubber stopper no bubbles from my oil pressure tube. Plain C maybe D. Any ideas where to look next, or how check things further.
nailbender is offline   Reply With Quote
Old 05-09-2019, 12:01 PM   #2
Ggmac
Default Re: No oil pressure [8BA]
Call the shop that built it ! ASAP just to make sure they can't come back and void any warranty. How close is the pickup from the pan ? Did they assembled the engine and the pan ? , intake ?
Old 05-09-2019, 12:16 PM   #3
flatjack9
flatjack9's Avatar
Did they pack the oil pump with STP or assembly lube to lubricate the gears?
Old 05-09-2019, 12:32 PM   #4
nailbender
pump just had oil, and turns fine
Old 05-09-2019, 12:35 PM   #5
nailbender
Hay the pickup tube might be a thing, I'm going to look in to that[ something else to check, thanks]
Old 05-09-2019, 12:38 PM   #6
marko39
You can check your oil gallery plug to make sure it is installed. It should have been removed for cleaning.
marko39 is offline   Reply With Quote
Old 05-09-2019, 12:46 PM   #7
JWL
Was a "Full Flow" filter added?
JWL is offline   Reply With Quote
Old 05-09-2019, 12:47 PM   #8
nailbender
The pickup tube is nice and close the bottom, not that
Old 05-09-2019, 12:48 PM   #9
nailbender
No filter
Old 05-09-2019, 12:51 PM   #10
nailbender
Oil galley plug??? maybe that's way the air seem to be coming out up in the block not any where else.
Old 05-09-2019, 01:05 PM   #11
rotorwrench
rotorwrench's Avatar
Maybe they forgot the idler gear in the back. You should get some oi pressure from just turning the stater with the spark plugs out.
Old 05-09-2019, 01:17 PM   #12
Willit Stop
Willit Stop's Avatar
Do 8ba's have an oil pressure relief valve in the valve valley? If so,was it installed? Just a thought.
Willit Stop is offline   Reply With Quote
Old 05-09-2019, 01:19 PM   #13
marko39
Plus, a 12 volt battery helps. You should see around 25 psi .
Old 05-09-2019, 01:32 PM   #14
nailbender
All good ideas and a pile of help. Takes me awhile to check each one. Still looking, this engine is all WAS all together with all the body fluids in it.
Old 05-09-2019, 01:35 PM   #15
alanwoodieman
had it happen before--oil gallery plug was left out
Old 05-09-2019, 01:39 PM   #16
nailbender
Guys I got to go to work, I'll be back and do some more looking. Thanks so much
Old 05-09-2019, 02:55 PM   #17
Ggmac
You don't want it too close , sometimes the pickup is too close and can't suck the oil it's blocked by the oil pan
Old 05-10-2019, 07:18 AM   #18
chap52
chap52's Avatar
Return it to the builder... No need to chase rabbits, if the builder is a "good guy" I am sure that he would rather find and fix the issue than have someone else "maybe" get it to work Chap
Old 05-10-2019, 07:51 AM   #19
nailbender
Had a day to think about this oil pressure problem. I made a plug with place to put some air into the block. Doing so there seem to be a lot of air exiting some where in the block. This laying on my back holding the hose and a light trying look and lesson. I've seem a picture of the oil system here [ford barn] and it looks like there should not be any where for mass amount of air to come out. I understand how the system works so I think or guess that there may be hole that is not suppose to be in the system. I wonder if I can make some sort low pressure pump to push oil up the oil pump hole so I can see something. Does this sound like a workable plan? I maybe thinking out loud. Thanks for all your replies .
Old 05-10-2019, 08:34 AM   #20
flatjack9
flatjack9's Avatar
Remove the intake manifold to see if the fuel pump pushrod bushing is in place.
