Old 04-13-2019, 06:47 PM   #21
Royal Ryser
Default Re: Old newbe needs help
I sure have received some good advice here. Next week I will follow up and see what I can do with the problem.
Hopefully, I can make contact with a good mechanic nearby.
Thanks to all.
Royal Ryser is offline   Reply With Quote
Old 04-13-2019, 11:00 PM   #22
dmsfrr
dmsfrr's Avatar
Originally Posted by rotorwrench View Post
They have an extended impeller pump available for the Thunderbirds. There is a baffle available but the extended impeller should do the trick. Clearing out any crud from the block is a whole other problem. The belt alignment is what caused the need for that pump spacer so that slowed the pump flow down.
There is an improved T-Bird pump spacer available that significantly improves flow thru the water pump.
But it isn't inexpensive...
https://asunow.asu.edu/20180403-solu...nderbirds-cool
https://thunderbird.us/
dmsfrr is online now   Reply With Quote
