Old 04-11-2019, 03:49 PM   #1
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default 1951 sedan hood brackets
Does anyone know about the(4)shoulder bolts that mount the 51 hood? I have one bolt that is stripped , I bought a set of new bolts but I don't know if they thread into a floating insert or a stationary nut.I think I can remove one bolt at a time but if it is a floating nut it will fall out when I separate the two and it will be trapped and loose behind the bracket My workshop manual is in the storage garage and I can't get to it until May so I would appreciate any suggestions. I have a feeling I have to remove the hood and place it on a blanketed table to replace the shoulder bolts ??? Thanks in advance, Barry B./ Ma.
Barry B./ Ma. is offline   Reply With Quote
Old 04-11-2019, 07:47 PM   #2
flatford8
flatford8's Avatar
Default Re: 1951 sedan hood brackets
Use some good penetrating fluid and just replace one at a time so it won’t lose the adjustment. The nuts shouldn’t turn. ........Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
flatford8 is online now   Reply With Quote
Old 04-13-2019, 11:05 AM   #3
Barry B./ Ma.
yes, I think That's the problem, the forward nut must be turning but I cant get to it to hold it, seems loose in there and I don't dare to get the bolt out then the nut will fall. Cut a hole in the bracket with the hood still mounted ??
Old 04-13-2019, 01:46 PM   #4
leon bee
I had to cut one of those to get a nut in there, but the hood was already off. Anyway, I just cut kind of a flap and then welded everything back so it's not noticeable. So if you can't cut a bolt, maybe cut that flap to get to nut.
leon bee is offline   Reply With Quote
Old 04-13-2019, 02:01 PM   #5
cas3
keep in mind if you get in there with a grinder, the sparks are hot enough to gouge in to glass and paint
Old 04-13-2019, 03:16 PM   #6
JSeery
JSeery's Avatar
Lesson learned long ago, grinders (or any spark producing device) and glass do not play well together!
