Old 03-24-2019, 07:58 PM   #1
Sid
Sid's Avatar
Default Basecoat clearcoat paint
Has any one had any experience with Limco Supreme base coat paint. Can you put PPG claer over it or use DT reducer in the basecoat? And yes I do know you shouldn't mix different brands but I do know some products are compatable with others. R-M,PPG,Dupont for example. I've never heard of Limco. I use PPG exclusively and have some Dupont products. This color I am dealing with was a special mix and I have a small area on the left front of roof to try to blend in. I have a little over over half a quart of this paint.
Sid is offline   Reply With Quote
Old 03-25-2019, 07:58 AM   #2
Ford blue blood
Ford blue blood's Avatar
Default Re: Basecoat clearcoat paint
I think it is a sub of BASF....not sure.
Bill, certified Ford nut.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
1956 Ford Crown Victoria
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 03-26-2019, 10:21 PM   #3
Y-8
http://refinish.basf.us/
BASF tech support is very helpful.
Y-8 is offline   Reply With Quote
Old 04-13-2019, 09:29 AM   #4
Michael Allen
How big a gambler are you? Would the various brands/components be compatible; maybe, maybe not. Might seem OK at first but fail later. I prefer to go with the "system". Good luck either way.
Michael Allen is offline   Reply With Quote
Old 04-13-2019, 11:43 AM   #5
Sid
Sid's Avatar
I've cleared Dupont with PPG. Used PPD and R-M together but never even heard of Limco until now. I,m not too worried about the reducer. It's the clear coat i'm more concerned about.
Old 04-13-2019, 06:34 PM   #6
56sedandelivery
56sedandelivery's Avatar
+2 on using a system that is designed to go together. I would not be willing to chance clear coating over something that may or may not be compatible.
56sedandelivery is offline   Reply With Quote
Old 04-14-2019, 09:03 AM   #7
Ford blue blood
If both are urethane systems it should be OK. The pros say use the same system from the base to the finished top coat. Solid advice, it helps isolate "finish problems" should they arise.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
