Old 02-26-2019, 11:19 PM   #21
Railcarmover
Default Re: Engine Stand
Originally Posted by daren007 View Post
Build your own side mount and save a bundle.
ran mine up in a jiffy
Railcarmover is offline   Reply With Quote
Old 02-26-2019, 11:27 PM   #22
Tim Ayers
Originally Posted by midgetracer View Post
I don't want to hijack this thread, but I use a Stipe type engine stand bracket, and I have a B engine with a Miller head. I am concerned that the weight of this engine (I want to avoid pulling the head) will be too heavy for this engine stand. I have visions of breaking off the pan flange. I need to redo the Burtz seal I have on the rear of the crankshaft, and I want to disassemble as little of the engine as possible. I think I need to polish the area where the slinger was a lot better or at least make sure that the drain back tube has nothing blocking the flow. Am I too squeamish about doing damage to the engine? I have over 10K in this engine, but the leak is really bothering me.
I would think the Miller aluminum head isn't too much heavier than a cast iron stock one. Curious if anyone has weighed them.
Tim Ayers is online now   Reply With Quote
Old 02-27-2019, 02:16 AM   #23
midgetracer
midgetracer's Avatar
i have the stock cast iron one, but haven't weighed it. It is very heavy though. Probably more than the stock flywheel.
midgetracer is offline   Reply With Quote
Old 02-27-2019, 04:35 AM   #24
denniskliesen
denniskliesen's Avatar
I made my own adapter for the side of the engine partly due to having the heavier HF engine stand. The pipe size is bigger for the rotating piece.
denniskliesen is offline   Reply With Quote
Old 02-27-2019, 06:18 AM   #25
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Originally Posted by Purdy Swoft View Post
I've got a Harbor freight engine stand and it can be connected to the rear of the engine . I use the engine stand adapter pictured in post number 6 that connects to the side water inlet . It works well and the engine can easily turned upside down .
Purdy,
I remember you traveled a LOOOONG way to a machine shop. Glad you have a Harbor Freight Store, near you.
I HATE folks that criticise them!!! Look at their website, they have more stuff than you can wave a stick at!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 02-27-2019, 07:35 AM   #26
Smitty
Smitty's Avatar
With the flywheel and housing in place the side mounted engine balances quite well. That is how they were set up on the KR Wilson stands. Easy to rotate
Smitty is offline   Reply With Quote
Old 02-27-2019, 09:19 AM   #27
Railcarmover
Originally Posted by BILL WILLIAMSON View Post
Purdy,
Bill W.
If you use a Harbor Freight stick they break when you wave them..
Old 02-27-2019, 10:13 AM   #28
DD931
DD931's Avatar
Railcarmover - Thanks for the picture!!!
DD931 is offline   Reply With Quote
Old 02-27-2019, 10:43 AM   #29
katy
katy's Avatar
These work: https://www.otctools.com/products/60...l-engine-stand
Old 02-27-2019, 12:45 PM   #30
1929 Red Tudor
1929 Red Tudor's Avatar
It does not get much simpler than this
1929 Red Tudor is offline   Reply With Quote
Old 02-27-2019, 01:37 PM   #31
daren007
Oh nooooo Bill. Never sell your welder. I would consider getting rid of my dog before my welder.
daren007 is offline   Reply With Quote
Old 02-27-2019, 04:57 PM   #32
AL in NY
AL in NY's Avatar
DD931; I believe you stated you wanted to leave the head and oil pan on the engine when you mount it to the engine stand. The side mount adapter is bolted to the engine using the water inlet and two bolts on the oil pan. If you use the side adapter, you'll have to remove the oil pan BEFORE you mount the engine to the engine stand. If you remove the flywheel and flywheel housing, you can use the rear of the engine to mount the engine onto the stand. Use the top two bolt holes(where the shims go) and the lower two flywheel housing bolt holes to mount to the engine stand. This lowers the engine so the center of rotation is nearer the engine's center of gravity. You can do all your disassembly and assembly with the engine mounted this way. But you'll have to dismount it to add the flywheel housing and flywheel again.
AL in NY
AL in NY is offline   Reply With Quote
Old 02-27-2019, 05:16 PM   #33
CarlG
CarlG's Avatar
You don’t have to remove the pan, only the two bolts where the engine mount goes.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-27-2019, 05:18 PM   #34
AL in NY
AL in NY's Avatar
CarlG: how are you going to remove the oil pan after you mount the engine on the stand using the side mount adapter?
AL in NY
Old 02-27-2019, 06:49 PM   #35
daren007
The two bolts that use the pan rail do not need nuts. You can use dowels for this. I had a local welding/fabricator shear and bend my adaptor plate. I had a template for them to use. I welded the two bolts to the plate and drilled the two water inlet holes as well as four holes to bolt the plate to my engine stand. I bolted the adapter directly to the stand face thus eliminating having to deal with fabricating a pipe.
Old 02-28-2019, 03:23 PM   #36
CarlG
CarlG's Avatar
You have to take the rest of the pan bolts out.
Alaskan A's
Old 03-01-2019, 02:28 PM   #37
100IH
Anyone who does this daily would put a drain pan under the drain plugs first thing and let it drip right up until time to mount the sling and lift the block out. then set it down a cart or on the floor for removing clutch and flywheel and then F/W housing. Then mount the adapter (you can remove the bolts that are in the way at the pan rail). Then up to mount on the stand.
100IH is offline   Reply With Quote
Old 03-01-2019, 10:09 PM   #38
denniskliesen
Originally Posted by katy View Post
6,000 lb revolver, I worked with one of those for years in my past of being employed. I had some big diesels, differentials, and transmissions on them before.
Old 03-03-2019, 01:13 PM   #39
Gene F
Gene F's Avatar
Eagle, what stand is this?
Old 03-07-2019, 11:42 AM   #40
eagle
eagle's Avatar
Engine is sitting in a corner, behind some stuff so hard to get a picture but this shows how I mounted it. Works fine for me. Its just the cheap Harbor Freight stand.
