I just bought a set of rebuilt shocks at a fair price. They do not say "Houdaille" on them and the rebuilder says they are repops from maybe the 70's. Made in Chicago. He says he used 80/90 wt. gear oil as fluid. In principal, that seems to be OK, but I'm interested in your comments! What's the viscosity of proper shock fluid?
I use straight 30 engine oil in mine
Use thicker oil to make up for wear.
The right fluid depends a lot on how tight the internal clearances are. If the rebuilder says 80/90 I would go with that.
Is there aa chance the thicker oil will slow down the leaking? I have two sets that came from a reputable rebuilder who is no longer with us. Both sets were filled by him and leaked from day one. The oil is about the consistency of hydraulic jack fluid and gave a fair ride but it is getting about dry now, so I have been reluctantly contemplating going with the heavier oil or tube shocks. I haven't had the best of luck with rebuilt shocks, all leak upon installation and a short ride. I have heard here that new shocks now don't leak if you spend enough money, but have never actually seen a shock that doesn't leak. Thanks for any suggestions.
I have a set of Brattons (bill stipe) that I have had for 4000 miles and they have been leak proof for that time. Yes they are expensive.
