Anygood tips on how to spread the springs on the hood to remove in install new??
I've read that to INSTALL them people put washers between the coils to EXPAND the spring. Would probably work just as well to remove the spring. FWIW
Paul in CT |
Her is an old thread. The washer method seems easiest.
https://www.fordbarn.com/forum/showt...rs+hood+spring |
I have installed them with a brake spring tool
1did my 41with washers
You can use a floor jack to spread them.
Bruce
Works good Lasts long time |
It is not hard to remove the whole hinge, then let it collapse. The spring will come off a lot easier then.
on sort of the same vane, do the new springs make the hood open up more? being new to these 48/52 trucks, I find the hood/over fender access a little lacking
This is a "for what it's worth" heads up. I changed the weak hood springs on my '48. I bought the replacements supplied by all the regular vendors, part #91A-16789. They were longer then the original springs, therefore the hood only opened half way up.
thanks gocatgo
