Old 10-16-2018, 07:18 AM   #1
wkuehnis
wkuehnis's Avatar
Question Whistle sound from new timing gear
Hi,
I installed a new “Model A Aluminum Timing Gear” and a new “Model A Camshaft Thrust Plunger with spring”.
Now I always hear a pretty loud whistle sound from there.( I didn’t have this before)
Is there maybe not enough lubrication ? How is it lubricated ?
Thanks for help
Willi
wkuehnis is offline   Reply With Quote
Old 10-16-2018, 08:28 AM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Whistle sound from new timing gear
It is lubricated by oil spilling out the front of the valve chamber on the side of the engine and falling down on the gears.
If the fan belt is connected, temporarily disconnect it and see if the noise is still there. The noise might be from the water pump or generator/alternator turning.
Does the pitch of the sound change with RPM? If so, you might be hearing the steel gear teeth contacting the aluminum gear teeth. Ford used a fiber gear to reduce noise.
Jim Cannon
"Have a Model A day!"
Old 10-16-2018, 02:14 PM   #3
PC/SR
I drill a 1/16" hole in the top of the plunger housing. Did you check the camshaft to crank gear clearance. Should be around .003-4
PC/SR is offline   Reply With Quote
Old 10-16-2018, 03:04 PM   #4
Dave in MN
Dave in MN's Avatar
The whistle or "squeal" may be the new plunger spinning in the front cover housing bore. It will often take a bit of time for this noise to subside. A few minutes usually.
The noise of a new aluminum timing gear mating with the steel crank gear is more of a whine. This too will subside with a bit of running time. Unless, as PC/SR brings up, there is lack of clearance.
Concerned about oil flow over the timing gear? Remove the timing pin and start the engine. If there is oil flowing over the timing gear it will work its way out of the timing pin hole.
Hope it's all as simple as I describe and it goes away within a short time.
Good Day!
Dave in MN is offline   Reply With Quote
Old 10-16-2018, 04:39 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
The timing gear plunger MUST be greased when it's installed. One guy didn't lube it during installation, and it took several heat/cool run cycles before the squeal finally stopped for good.
Old 10-17-2018, 03:07 PM   #6
PC/SR
Dave is right that oil will come out of the timing pin hole if left open. Plenty of it. I proved this scientifically on a 30 mile drive.
Old 10-18-2018, 03:45 AM   #7
wkuehnis
wkuehnis's Avatar
"Remove the timing pin and start the engine. If there is oil flowing over the timing gear it will work its way out of the timing pin hole."
Thanks, this is a very good and simple test. Thanks
Old 10-18-2018, 03:48 AM   #8
wkuehnis
wkuehnis's Avatar
Wink Re: Whistle sound from new timing gear
Funny - 2 weeks ago, I made about 1500 miles with my A - so you would stop about 50 times for this test ?
