Old 09-21-2018, 09:33 PM   #1
Russ/40
Russ/40's Avatar
Default Head Gasket for the 6:1 Iron head
Your recommendations please on an "A" motor with a Snyder 6:1 head
Old 09-22-2018, 12:41 AM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Head Gasket for the 6:1 Iron head
I would use the best gasket, although I see in 2017 brattons they recommend the modern silicone impregnated one. I have the 5:5 head with .125” bore , and I used the best.
Old 09-22-2018, 12:53 AM   #3
Dodge
The best brand graphite composition gasket. That modern silicone impregnated one won't
work on the 6:1 head.
Dodge is offline   Reply With Quote
Old 09-22-2018, 04:18 AM   #4
Bruce of MN
Bruce of MN's Avatar
Snyder's also recommends the silicone item for 6:1 and CW Moss, that sells the graphite, says that it is "Best for aluminum heads." http://www.cwmoss.com/site/wp-conten...alog-Final.pdf p.43
I already have the silicone for my soon-to-be-installed 6:1 head and am interested in the pros and cons.
Old 09-22-2018, 06:21 AM   #5
P.S.
The "silicone impregnated" gasket is a ticking time bomb. The question is not "if" it will fail, but "when". When it fails, you end up with a crankcase full of water. Mine failed after about 5 years. It just turned to goo. Took 3 weeks to clean the block and head properly for the new gasket.
P.S. is offline   Reply With Quote
Old 09-22-2018, 07:58 AM   #6
JRN1967
JRN1967's Avatar
When I installed my 6:1 head I used this gasket "Model #B-6051-C".
BEST brand gasket, part number 573G.
It's only been a little over a month, but so far so good.
JRN1967 is offline   Reply With Quote
Old 09-22-2018, 08:21 AM   #7
Glen in Hillman MI
The Best graphite.
Glen in Hillman MI is offline   Reply With Quote
Old 09-22-2018, 09:44 AM   #8
1931flathead
That what Snyder's want you to uze
1931flathead is offline   Reply With Quote
Old 09-23-2018, 02:01 AM   #9
old31
I am using the 573G on a 6.1 with 3,500 miles and so far so good.
old31 is offline   Reply With Quote
Old 09-23-2018, 06:49 AM   #10
Dave in MN
Dave in MN's Avatar
I used Snyder's silicone ringed gasket for 6+ years on the engines I built in long block form. I constantly had to remind my customers to torque the head multiple times. If they did, they had little problems with using them. Those that did not keep on a schedule to retorque them had trouble and complained about it.
I tried their new composite "Best" gasket 2+ years ago and now only use that one. It requires much less re-torquing; it usually reaches it's equilibrium after three re-torques.
That said: I have about four of the silicone gaskets "new in the wrapper" if someone wants a deal!
Good Day!
Dave in MN is offline   Reply With Quote
Old 09-30-2018, 04:35 PM   #11
john in illinois
john in illinois's Avatar
X 2 for Best gaskets. I have them on my Tudor 4 cyl and my Flathead.
John
john in illinois is offline   Reply With Quote
Old 09-30-2018, 08:24 PM   #12
denniskliesen
denniskliesen's Avatar
The most recent Best gasket I bought for a Model A was a 509G. The only difference is the 2 small holes between cylinders 2 & 3. They still have the 573G, and it is for the Model B block. Notice in the picture there is a Best 573 on top of a Best 509. Both are GraphTite. Notice the holes in the 573 and no holes in the 509. All other holes and shape are exactly the same.
denniskliesen is offline   Reply With Quote
Old 10-01-2018, 12:08 AM   #13
Dodge
Some places are just stocking the B gasket as they fit both.
Old 10-01-2018, 01:31 AM   #14
apbright
apbright's Avatar
The graphite 'Best Gasket' (referred to by others here) is the one recommended to me by a respected engine rebuilder. He indicated that the silicone-impregnated one, although seductively modern with its looks, has been found to leak prematurely (as, indeed, also indicated by others here). He also mentioned that some have had good experiences with the silicone-impregnated gasket, but that good experience has not been consistent.
apbright is offline   Reply With Quote
Old 10-02-2018, 07:52 AM   #15
Nosetime
Nosetime's Avatar
Did anyone use the copper spray sealer with the Best graphite?
Nosetime is offline   Reply With Quote
Old 10-02-2018, 08:56 AM   #16
ryanheacox
ryanheacox's Avatar
I have, it worked well. Pulling the head at the rebuilder showed the gasket had bonded well to the head and block.
Old 10-02-2018, 10:29 AM   #17
PC/SR
I use the copper spray on the Best graphite gasket with a 7:1 head. Tighten to 60bls. It does seal well. I get the head off by loosening the head nuts a few turns and turn it over with the ignition off.
PC/SR is offline   Reply With Quote
Old 10-02-2018, 10:53 AM   #18
California Travieso
Send a message via Yahoo to California Travieso
Speaking of the Copper Spray, what happened to the Copper gaskets that people were recommending for High Compression Heads until recently?
David Serrano
California Travieso is offline   Reply With Quote
Old 10-02-2018, 09:14 PM   #19
Tom Wesenberg
Tom Wesenberg's Avatar
David Serrano
That's all that I use.
Old 10-02-2018, 11:45 PM   #20
Russ/40
Russ/40's Avatar
Which one Tom?
