Old 02-22-2011, 05:06 PM   #1
Ryan
Administrator
Ryan's Avatar
Default Fleathead Engine Stands
You know what I got a thing for? Flathead engine stands... But I know absolutely nothing about them. I'm betting some of you fellas know everything there is to know about them. ... To read the rest of this blog entry from The Ford Barn, click here.
Ryan is offline   Reply With Quote
Old 02-22-2011, 05:21 PM   #2
Mark Slight
Mark Slight's Avatar
Default Re: Fleathead Engine Stands
Almost every Ford dealership had one or more of these engine stands made by K-R Wilson. Who was one of the major suppliers of equipment to Ford dealers at the time 30's to 50's as I remember.
They are very heavy and safe to work with, now days expensive and expensive to ship. Well worth the investment if you are going to do several engines or more. Could be a club project.
Mark
Mark Slight is offline   Reply With Quote
Old 02-22-2011, 06:38 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
I have 2 of the K.R. Wilson engine stands like the one pictured. One has the base and the other does not. I am looking for a base . If push comes to shove I could fabricate one out of heavy gauge steel. Makes working on a flathead V-8 or V-12 nice. The whole engine can be assembled exept for the exhaust manifold.
Ken/Alabama is online now   Reply With Quote
Old 02-22-2011, 06:40 PM   #4
Glenn Thoreson
Glenn Thoreson's Avatar
K.R. Wilson X-6000 engine stand. I wish I had one. These are the only thing that will provide a safe, secure stand to work on the flathead engines.
Glenn Thoreson is offline   Reply With Quote
Old 02-22-2011, 08:41 PM   #5
Roadster62
Roadster62's Avatar
Question #1 does a Flathead block weigh less than the stand?
Roadster62 is offline   Reply With Quote
Old 02-22-2011, 08:43 PM   #6
MattStrube
MattStrube's Avatar
I love those things...and have been thinking about picking up an old kr Wilson catalogue so I can check out more of their stuff to put on my wishlist. Wondering what catalogue would have the most flathead v8 related items?
MattStrube is offline   Reply With Quote
Old 02-22-2011, 08:52 PM   #7
sikopal
True, the KR Wilson is a solid stand but not the "only" one, Clayborne built a solid stand for the flathead engine that works well!
Will post a photo of mine later!
sikopal is offline   Reply With Quote
Old 02-22-2011, 09:23 PM   #8
FlatheadTed
FlatheadTed's Avatar
This one mounts on the exhaust manifold a lot of modern ones mount on the bell housing and the engines have been known to brake of .That is the engine bell housing can crack ,This job has the 16 holes for when you are doing a valve job ,A nice piece to have in your Flat-head shop .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 02-22-2011, 10:44 PM   #9
Flathead Fever
Flathead Fever's Avatar
I have a KRW stand that is missing the parts tray and the base.
According to the 1940 KRW catalog they had sold 14,000 of them in the last 20 years. In the catalog the base looks like it was an option, also the base in the 1940 catalog is not cast like the one in the picture, it is made from a 30X30X1/4 steel plate. The tool tray is also different.
Old 02-23-2011, 07:50 AM   #10
John Kennedy
John Kennedy's Avatar
I converted a cheap-o 3 leg stand into a wide base 4 leg stand, and built the engine holder out of 1/4" plate drilled to bolt onto the exhaust ports. The plate is welded to a thick angle-cut tube that rotates in the stand.
Actually patterned after a HAMB post I found.
I can take pictures and post em up, if you'd like.
John
Building a 29 Sedan on 32 chassis........ very slowly....
John Kennedy is offline   Reply With Quote
Old 02-23-2011, 07:51 AM   #11
John Kennedy
The angle cut tube is what sets the engine level.
Old 02-23-2011, 09:06 AM   #12
Rem/Mo
Rem/Mo's Avatar
Great thread and thanks for the pics.
I have one of those that I have beem trying to soak free to get the head to turn. I had no idea that there was a base for them. Looked like it would have to be fastened to the floor to be stable. It is good to see all the attachments that were available. I will have to be on the lookout for some of them. When I get mine loosened up and working I plan to mount an old flattie on it for display. It would be a good use for a cracked block that would have no other value.
Rem/Mo is offline   Reply With Quote
Old 02-23-2011, 09:37 AM   #13
cbillelder
I've had one of these stands for about 40 years now. Mine also has the worm gear box for rotating the motor on the stand. Very nice! You can position the engine at any angle you want. It came with the cast square base, but I took it off and threw it away and built a T-shaped base from 4" channel. The square base was too wide to fit between the legs of my engine lift. This all happened 40 years ago. If I had known how valuable these bases were, I would have kept it!!
cbillelder is offline   Reply With Quote
Old 02-23-2011, 11:37 AM   #14
lowride
Here are two KR Wilsons, One with and one without a base. Then there's another that we made.
lowride is offline   Reply With Quote
Old 02-23-2011, 11:50 AM   #15
Capn John
Capn John's Avatar
Stumpy's Fabrication Works makes adapters for a normal engine stand. the adapters bolts to the exhaust side of the block so you negate the chance of breaking the rear of the block. http://stumpysfabworks.zoomshare.com...and%20adapters
Capn John is offline   Reply With Quote
Old 02-23-2011, 12:26 PM   #16
NoSurf
NoSurf's Avatar
I would love to have one of those KR Wilson stands.
I built my own adapter to mount my flatty to my crappy modern chinese engine stand.
NoSurf is offline   Reply With Quote
Old 02-23-2011, 01:42 PM   #17
Cool Hand Lurker
Cool Hand Lurker's Avatar
I might be wrong, but those welds don't look like they have enough penetration. You might want to clean and reweld them so you don't drop an engine. Don't ask me how I know....
Cool Hand Lurker is offline   Reply With Quote
Old 02-23-2011, 02:47 PM   #18
NoSurf
NoSurf's Avatar
Appreciate your comments.
Old 02-23-2011, 07:09 PM   #19
John Kennedy
I know we're getting a bit off-topic from the KR Wilson stands, but here's mine...
Old 02-23-2011, 08:48 PM   #20
nostalgicford
nostalgicford's Avatar
here's one I had powder coated...coater did it fflat black...would have looked much better hi gloss
nostalgicford is offline   Reply With Quote
