Old 06-20-2018, 09:10 AM   #1
john in illinois
john in illinois's Avatar
Default flow direction in slingshot manifold
In an Edelbrock slingshot does the rear carburetor feed the front cylinders.
John
john in illinois is offline   Reply With Quote
Old 06-20-2018, 09:59 AM   #2
Bursonaw
Bursonaw's Avatar
Default Re: flow direction in slingshot manifold
Yes, it does. Here is a picture of a slingshot manifold with the high rise removed. Both carbs feed in the center of the manifold.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 06-20-2018, 10:26 AM   #3
john in illinois
Thanks Tony. I am having trouble with lean mixture on front cyls and I wanted to
be sure which carb to check. I have put about 300 miles on the slingshot and really like it. Great throttle response.
John
Old 06-20-2018, 12:42 PM   #4
flatjack9
flatjack9's Avatar
With an open plenum, both carburetors feed both the front and the back cylinders.
Old 06-20-2018, 07:03 PM   #5
Talkwrench
Talkwrench's Avatar
this help
Old 06-21-2018, 07:15 AM   #6
john in illinois
Thanks for the inside pics . I did not remember the inside design when I put it together.
The carbs do empty into a plenum ,but they do each flow to one end. I had clean plugs in the front and rich black plugs on rear. I have since adjusted float level and a leaking power valve and plugs are the same.
John
Old 06-21-2018, 09:49 AM   #7
itslow
itslow's Avatar
Both carbs will feed both the front and rear cylinders. The divider would need to extend down into the lower manifold in order to make it so that the carbs only flow to their respective ends of the engine.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 06-21-2018, 02:08 PM   #8
rotorwrench
rotorwrench's Avatar
Vic Senior's sling shot was one of the first dual carb & dual plane (180*)manifolds marketed as speed equipment. He worked with Tommy Thickstun on the first of the PM manifolds but felt that his design with shorter runners would be better and Tommy sort of scoffed at his idea (Tommy was an engineer & Vic wasn't). Vic found the folks that would help him make his own design and that was the beginning of Edelbrock Speed Equipment.
The dual plane allows for about the same distance in the runners on each side and for a cross over to the other on each side. One side crosses over the top and the other on the bottom. It makes for a better balance of mixture flow and less tendency for fuel pooling in there.
Old 06-21-2018, 02:37 PM   #9
scicala
scicala's Avatar
The only way (without a flow bench) to see if one carb is running richer than the other is to block off the mounting flange for one of the two carbs, and run one carb at a time. It may just be the nature of the manifold distribution that make some spark plugs darker than others.
My opinion and experience says that if one carb is richer than the other, the mixture should basically equal out in the manifold after the carbs. Still could be caused by one carb being too rich.
Sal
scicala is offline   Reply With Quote
Old 06-21-2018, 02:41 PM   #10
scicala
scicala's Avatar
John
If you didn't already, you need to clean the plugs before you evaluate it being too rich, since once a plug gets black, it takes for ever for it to go away even when running the correct mixture.
Sal
Old 06-21-2018, 06:51 PM   #11
rotorwrench
I don't think you could track it to one particular carb anyway. Two of the venturis (one on each carb front to rear) will reach to the front on one side but that pair doesn't feed both front cylinders. It feeds the front on one side and the next one back from the front on the other side. The other pair of venturis on the opposite plane feeds the opposite two of the front four cylinders.
When you check mixture using the spark plugs, you have to use a scientific procedure. I'd suggest running it at a particular rpm down the road for a while then shut the ignition off & coast to a stop. In other words, don't let it idle, just shut it off. Check your plugs then and you can see what it's doing for that power setting. If you let it idle down for any length of time, it will be affected by the idle circuit and change your plug readings. It can be a bear to sync the carbs at idle. It may be easier with an air fuel ratio tester.
Old 06-21-2018, 09:33 PM   #12
Andy
A digital fuel air meter would be useful. 97 carbs can richer up with restrictive air filters. The fuel bowl is not vented to the air horn. Maybe the front filter is more restrictive or the carb has some internal difference. The fuel dump tubes can be easily crushed and that will change the mixture.
Andy is offline   Reply With Quote
Old 06-22-2018, 10:12 AM   #13
john in illinois
Thank you for all your replies and suggestions. Here is what I have done to date.
Discovered front carb had power valve leak.
Replaced valve and leak tested over white paper for 1 hour.
Looked into air horn while running. Reved up to very high idle, fuel was dribbling out front emulsion tubes.
Lowered free end of float 3/32” on both carbs. Drove it withclean plugs in 4 and 8. Seems to be even now. Very short 15 mi.test drive.
I do have an A/F meter and have used it to get approx best jetting.
Engine tilts 3* to rear snd I hope I that will work ok.
Car has always run excellent even when things are not quite right.
John
File Type: jpg F90FC891-FDD5-4E12-8212-BC7C0C7BA338.jpg (88.9 KB, 38 views)
Old 06-22-2018, 03:26 PM   #14
rotorwrench
I've seen folks make special wedge shaped carb spacers to get a more level positioning. Some just put taller tires on the back & smaller ones on the front. If it works OK then run it the way it is.
Old 06-23-2018, 07:25 AM   #15
john in illinois
I think with the lower float levels it will work fine. If it ever stops raining I plan to drive with A/F meter hooked up and check it.
John
Old 06-23-2018, 07:37 AM   #16
Flatout
Flatout's Avatar
I'm running my slingshot with progressive linkage on the carbs. It operates like a single 4-barrel carb. For reduced fuel consumption on a trip, I slide a shim under the secondary carb to block it. It works out well on my nearly stock 34 engine.
Flatout is offline   Reply With Quote
