Old 04-19-2018, 08:13 PM   #1
melisahe
melisahe's Avatar
Default best way to fit glass in 37, 38, 39 windshield frame
At the point where I'm installing the glass in my 38 coupe. Any tips on how to get the glass in the windshield. It's a two piece. Just doesn't what to go in, tried dawn and soapy water, Any and all help will be most appreciated. Thanks Mike.
melisahe is offline   Reply With Quote
Old 04-19-2018, 09:14 PM   #2
alanwoodieman
Default Re: best way to fit glass in 37, 38, 39 windshield frame
I use soapy water and a couple of the bar clamps from HF to help hold it together and to help pull the frame together, as I use a rubber hammer-pound-pull up clamps-pound-clamps. It is a bear to do--just did two, one in a 36 another in a 35 and soon will do one for a 39.
Old 04-20-2018, 08:43 AM   #3
melisahe
melisahe's Avatar
tks -I'll try again. Just doesn't want to reach the bottom of the frame. thought I might use a thinner glass bead.
Old 04-20-2018, 11:09 AM   #4
Paul Selfe
Paul Selfe's Avatar
I use WD40 for both removing and replacing glass in my 39 (37 frame). there are different thickness tapes, so make sure your tape is not too thick for the fit. Once the tape is applied to the glass, spray it with WD40. That will soften the tape and allow it to slide into the frame. If it dries too quickly, spray on more until you can bring the frame sections together. The WD40 will evaporate and you will have a good fit. An old glass man taught me that. Paul Selfe.
Paul Selfe is offline   Reply With Quote
Old 04-21-2018, 08:28 AM   #5
51504bat
51504bat's Avatar
The glass man who sold me the windshield and glass setting tape told me NEVER use WD40. Something about it continues to allow the tape and glass to move. Anyway his advise was window cleaner to lubricate the glass. It could be you have the wrong thickness glass tape. JMO
