Old 04-10-2018, 03:55 PM   #1
russcc
Default Drilling for oil
Thank you all for your posts, diagrams and photos. Couple of photos of the vertical drilling in the 59L block on the Bridgeport. #1 photo is the setup.
The 59L has a pronounced boss where the intersecting hole is drilled for the return. #2 photo. The head on the Bridgeport was tilted to drill that intersecting hole that is at an angle on the 59L. The last photo is a diagram of the drilled holes, and location of the set screw overlaid on the block photo.
There was some confusion between a 59 and 8BA block as to the location of the new return hole, and jig. A jig would have come in handy drilling the horizontal hole for the 3/8 pipe thread as that was a pain with the hand drill.
Old 04-10-2018, 05:54 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Drilling for oil
Nice job. Sure is good to have a mill and a lathe. I'm jealous!
Thanks for posting the photos. Be sure to post photos of how you run the lines and mount the filter.
19Fordy is online now   Reply With Quote
Old 04-10-2018, 07:10 PM   #3
russcc
Looking for suggestions on where to mount the remote spin off filter on a '40 Coupe. Preferably where you can change the filter without to much of a mess. Thank you Fordbarners. That Bridgeport was found in scrap metal yard, and was bought for scrap. It worked fine initially for my stuff, but I eventually had some bearing, pulley and belt work done on it.
Old 04-10-2018, 07:56 PM   #4
40cpe
40cpe's Avatar
On my '38, your '40 should be similar, I mounted it on the outside of the frame rail under the left front fender. It is convenient to change, and more importantly to me, the lines to/from the filter are below the ports on the engine so the oil in the lines doesn't drain back into the engine to have to be refilled at startup.
Old 04-10-2018, 09:27 PM   #5
flatjack9
flatjack9's Avatar
On my 39 I have it mounted under the left front fender behind the fender brace.
Old 04-11-2018, 01:48 AM   #6
Lawrie
Lawrie's Avatar
Look up my old post under remote oil filter!that is my best setup yet,
100% full flow,been on our 33 for while now and I have made a few for the engines I do
Lawrie
Old 04-11-2018, 11:42 AM   #7
glennpm
glennpm's Avatar
Great setup, machinery and drawing Russ!
Old 04-11-2018, 05:08 PM   #8
37don
I also mounted mine behind the left frt wheel. Hangs at a 45 degree angle.Has worked fine for several yrs and makes a neat setup under the hood.
Regards, Don
37don is offline   Reply With Quote
Old 04-11-2018, 06:51 PM   #9
Talkwrench
Talkwrench's Avatar
I'd like to see pictures of these ones under the fender...
Old 04-12-2018, 06:07 PM   #10
russcc
Those pictures of the left fender location sure would be appreciated by many. Thank you Fordbarners.
Old 04-12-2018, 07:08 PM   #11
flatjack9
flatjack9's Avatar
I'd have to get my car up on a lift.
