Old 03-13-2018, 06:29 PM   #1
johncusano
johncusano's Avatar
Default Crab style Distributor Cap
Will the crab style replace the Y style cap that has the 8 plug wires jammed into the two holes? With out to much modification, 1948 ford with 59 engine,dont know the model of the dist. its stock two bolt. Thanks for any help.
johncusano is offline   Reply With Quote
Old 03-13-2018, 06:40 PM   #2
fordwife
Default Re: Crab style Distributor Cap
Yes,but the distributor has to have two clips to hold it on rather than the bail like your dist. would have.
fordwife is offline   Reply With Quote
Old 03-13-2018, 06:48 PM   #3
FortyNiner
FortyNiner's Avatar
The stock 46 y-style disty has two hold down clips. There was a bail on the helmet version.
[Edit: there is also a bail over the top cap in addition to the clips holding the lower cap]
Old 03-13-2018, 06:57 PM   #4
johncusano
johncusano's Avatar
Ok thanks,do you know if the rotor's are the same
Old 03-13-2018, 07:53 PM   #5
fordwife
No, they are different. Most ford suppliers will have both types.
Old 03-13-2018, 08:21 PM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
The '42 crab cap distributor had two spring clips that held the cap in place. The rabbit ear cap with two openings for wires had a single bail that held its two caps to the distributor body. The earlier helmet distributors had two bails, one on each side to hold its two inner and two outer caps in place.
Many of the suppliers sell a kit with all parts and pieces required to convert the rabbit ear caps back to a crab cap. You also need to change the rotor.
John
Old 03-13-2018, 08:28 PM   #7
FortyNiner
FortyNiner's Avatar
All I know is that my 46 rabbit ear distributor cap has two hold down clips and a bail over the upper cap.
Old 03-13-2018, 11:25 PM   #8
38bill
38bill's Avatar
Yup, you just need the two clips and the rotor that are made for the crab cap to convert the two part dist cap. Check to make sure the crab wires will clear the belt(s).
38bill is offline   Reply With Quote
Old 03-14-2018, 07:27 AM   #9
Mart
Mart's Avatar
I have a crab type distributor on my French motor.
The clip conversion parts are easily available.
I bought a new set of plug wires and spec'd 90 degree terminals coming out of the cap. This keeps the wires out of the way of the pulleys.
Mart.
Old 03-14-2018, 08:06 AM   #10
Charlie ny
John,
Before you reinstall the distributor on the motor check for rotor internal
interference with the cap. The crab cap registers on the outside of the distributor
housing and the later type cap registers on the inside of the distributor housing.
Charlie ny
Old 03-14-2018, 09:35 AM   #11
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Third Generation Ford has the clips you need and they also have the cap and rotor. Great people to deal with , they have a ebay store......
https://www.ebay.com/itm/NEW-1942-46...BXaHwB&vxp=mtr
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 03-14-2018, 10:06 AM   #12
JM 35 Sedan
I'll second that!! Just received an order from 3rd Gen, and will place another soon.
John
Old 03-14-2018, 10:18 AM   #13
JM 35 Sedan
You are correct. There are two small bail spring clips on the outside of inner cap, and one large bail that goes over top of the outer cap.
John
Old 03-14-2018, 10:22 AM   #14
flatjack9
flatjack9's Avatar
The rotor is the same as the 49 - 53 rotor.
Old 03-14-2018, 11:39 AM   #15
johncusano
johncusano's Avatar
Thanks for all the info. Parts are on order.
Old 03-14-2018, 02:45 PM   #16
richard crow
there is a different set of wire looms used on the crab dist. eng.if you want a neat set up you will need them
richard crow is offline   Reply With Quote
