Old 02-03-2018, 12:06 PM   #21
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Testing Echlin FA49 condenser with capacitor tester
Originally Posted by marko39 View Post
after reading these posts i did some testing with my Sun Master Motor Tester on several nors. condensers and a new FA49. tests are for resistance,capacity and leakage. all the nors. ones showed low capacity,less than .30 and most showed leakage. i thought the tester was not correct until i tested the FA49 which showed no leakage and .35 mfd. so, dont buy any old stock condensers as your chances of getting a good one are slim.
Yep i bought a large box of helmet condensors at a auction once, 95% wouldnt pass the condensor leakage testing . Although these were new in the box i think they either dry out or attract moisture but very seldom check a nos unit that it will pass testing....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 02-03-2018, 01:08 PM   #22
corvette8n
corvette8n's Avatar
I've seen a few NOS ones on eBay for $10-20 each, I just laugh when I see that.
Old 02-03-2018, 01:08 PM   #23
36fordguy
Nobody has talked about the G factor the most important parameter for a capacitor. This is the internal resistance of the capacitor. The industry uses different methods to measure this value. The G value is either the series or parallel resistance at an established frequency 36fordguy
36fordguy is offline   Reply With Quote
Old 02-03-2018, 01:42 PM   #24
flatheadmurre
flatheadmurre's Avatar
Enlighten me...ESR, DF and Q i´m familiar with...G are we talking Conductance ?
Old 02-03-2018, 06:16 PM   #25
rotorwrench
rotorwrench's Avatar
Capacity, leakage, and resistance are the normal tests for most caps. I haven't heard the term G factor in relation to resistance but I wasn't trained to test all types of capacitors either. It seems like it is the quality of a capacitor at operating frequency or is that Q factor. I forget a lot of the electronics training I've had. Been too many years.
Old 02-03-2018, 06:55 PM   #26
tubman
tubman's Avatar
Know what the "G" spot is, but I never heard of it in relationship to capacitors. I'll check with my EE buddy and see what he has to say.
Old 02-03-2018, 08:03 PM   #27
Teltruck
Teltruck's Avatar
Originally Posted by BUBBAS IGNITION View Post
Guys this is the best automotive condensor tester ever made . Buy them on ebay at a good price from time to time.
https://www.ebay.com/itm/Used-Perry-...sAAOSw-RFaUsPJ
Owner dont know how to test a condensor.......
Bubba:
I have the Perry Davis Ignition -Coil and- Condensor Tester you recommend. I can test Condensor fine. However, would it be possible to test a Coil on the bench with this unit? If so, would you let me know how it would be done! Thanks very much.
Bob
Teltruck is offline   Reply With Quote
