Old 01-14-2018, 07:26 PM   #1
Leatherback 57
Leatherback 57's Avatar
Default Valve Adjustment
I installed new valves and ran adjusters all the way down. I have at least .050 clearance except 2 valves that I had to grind stems.Adjusted all to .015. Couple valves only have max .025 left on adjusters before they bottom out.Should I grind those stems to allow more adjust room or am I ok?
Leatherback 57 is offline   Reply With Quote
Old 01-14-2018, 07:27 PM   #2
Leatherback 57
Default Re: Valve Adjustment
That's .010 more left.
Old 01-14-2018, 07:41 PM   #3
Patrick L.
Patrick L.'s Avatar
If they ever need to be adjusted more than the .010" there is something wrong.
Old 01-14-2018, 08:00 PM   #4
700rpm
700rpm's Avatar
Something is not right here, if I am interpreting your post correctly. May I ask what set of instructions you are following for setting your valves, and if you are using modern valves and/or a modified cam?
Ray Horton, Portland, OR
Old 01-14-2018, 08:19 PM   #5
Leatherback 57
All my old valves had the stems cut down. Before doing valve job, I adjusted Al lifters down to bottom. Ground 3 angle seats and installed new valves and lapped in. I use the plus 9 method for valve adjust. Clearance before adjusting valves as noted. After adjusting all valves to.015 a couple lifters only have .010 left before they bottom out. The stems I ground allowed for. 050 extra for further adjustment if needed. Usually clearance gets larger with wear. Just wandered if I should give the2 valves a stem grind or let go.
Old 01-14-2018, 08:25 PM   #6
Leatherback 57
Using original style valves,new split guides and springs
Old 01-14-2018, 08:25 PM   #7
glenn in camino
glenn in camino's Avatar
I've adjusted mine to .012 intakes and .014 exhaust
Old 01-14-2018, 08:59 PM   #8
40 Deluxe
On a flathead engine I suspect that, if anything, clearances are going to tighten up with miles as the valves wear into the seats. Not much else there to wear. The heel of the cam lobes will never wear, nor will the stem and lifter faces. If the bottoms of the lifters wear, kiss the cam goodbye in short order.
On overhead valves, clearances can get larger with wear: pushrod tips, rocker arm faces and pivot points all wear.
Old 01-14-2018, 09:02 PM   #9
700rpm
700rpm's Avatar
Well, that all seems OK on a second reading. For a driver I usually set my valves at .011in and .014ex, but this gets down to person prefs. I just aet my coupe at .015ex and that seems a little noisy. Funny how .001 can make a diff. When the weather allows I'll go back to .014.
Old 01-15-2018, 12:17 PM   #10
Purdy Swoft
Purdy Swoft's Avatar
I have set mine on sixteen thousants , Intake and exhaust . More time on the seat better cools the valves and reduces the chance of burning valves. Snyders recommended this setting , years ago and it has worked good for me . My reground Winfield super street 3/4 race cams use the same sixteen thousants gap .
Old 01-15-2018, 01:09 PM   #11
jwilliams81
jwilliams81's Avatar
I used the 13 and 15 that is in the Les Andrews book
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 01-15-2018, 02:26 PM   #12
George Miller
George Miller's Avatar
Plus one. Flathead will loose clearance.
George Miller is offline   Reply With Quote
