Old 09-03-2017, 09:44 PM   #81
cwh
cwh's Avatar
Default Re: '41 Ford COE questions
My old COE is back on the front burner. Plan is to have it painted this winter and back on the road in the spring. Charged the battery up this summer and took it for a little drive without doors and fenders. I've got the cab removed and I'll have it sandblasted soon.
“Don’t ask yourself what the world needs. Ask yourself what makes you come alive, and go do that, because what the world needs is people who have come alive.” Howard Thurman
cwh is offline   Reply With Quote
Old 09-04-2017, 06:12 AM   #82
jrvariel48
jrvariel48's Avatar
That is one awesome looking truck!!
jrvariel48 is offline   Reply With Quote
Old 09-04-2017, 10:19 AM   #83
5851a
Truck and the shop!
5851a is offline   Reply With Quote
Old 09-04-2017, 01:34 PM   #84
cwh
cwh's Avatar
Originally Posted by 5851a View Post
Truck and the shop!
Yeah, that'd be my dads 50x50 hangar. His cub is on floats on the lake through the summer. He's pretty generous with his shop space.
Old 09-04-2017, 03:33 PM   #85
alanwoodieman
just say your post--looks like you are finally getting some work done on it. I have been slow getting my 1 1/2 ton finished, but making progress, will get some pictures this week. drive the 3/4 ton all the time. I also bought a half finished 48 F1, apparently I cannot pass one up.
Old 09-04-2017, 05:55 PM   #86
cwh
cwh's Avatar
Right on. I'm digging that Ford flatbed.
Old 09-08-2017, 06:46 PM   #87
41panelmark
41panelmark's Avatar
Originally Posted by cwh View Post
I recently bought a 41 Ford cabover. It's a real solid truck and it runs like a top. I've never owned a vehicle this old and with the flathead engine and 6 volt electrical system(actually runs on 12v at this time). I have a few questions regarding both the powertrain and the electrical system.
First off, the truck has just 10600 miles on it but when the previous owner got it the engine was locked up. He got it loosened up with diesel and it runs great now. It doesn't smoke at startup but after 5 or 10 minutes the exaust gets hot and the oil in the exhaust system starts burning. The truck hasn't been run very much at all for the past years. I'm wondering if this is residual or do I need to replace the rings? I would have thought that if the rings were the culprit it would smoke immediatly. Any thoughts, suggestions?
The truck has really old bias/ply tires. It does vibrate a little up to say 15 but then after that it really developes a shimmy. The U joints seem tight as does the carrier bearing. Is the rear bearing in the 4 speed transmission a problem on these trucks?
Finally the electrical system had a meltdown two owners ago. It currently has a 12 volt battery wired through an ignition switch and solenoid to the starter and coil. All the original wiring is gone. Should I go to a 12 volt system or back to original? Who would be the best source for a wiring harness for the truck? Any and all input is appreciated.
Thanks for your ear and hope to have a reliable runner soon.
Chris
Very nice, let's see more photos!!
41panelmark is offline   Reply With Quote
Old 09-08-2017, 06:49 PM   #88
41panelmark
Allen, that bed project is coming along nicely.
Old 12-26-2017, 12:02 AM   #89
cwh
cwh's Avatar
Few update pics. Got the cab sandblasted. Now I'm welding in new sheet metal for some rust the sandblasting revealed. Some pitting where the fender welting held in the moisture.
Old 12-26-2017, 07:08 AM   #90
KDL
KDL's Avatar
I like it! Keep the pictures coming.
KDL is online now   Reply With Quote
Old 12-26-2017, 09:13 AM   #91
alanwoodieman
cwh--wow you are sure making progress with the cabover! Need to get my butt in gear and have my truck back on the road in the spring. a few pictures of the 38 cabover my buddy had and sold--I think it is Tx now. will get some updated pictures of my 1 1/2 ton soon
Old 12-26-2017, 04:18 PM   #92
cwh
cwh's Avatar
It's coming along. I finally brought the cab home from my dad's hangar. It's a whole lot easier to get motivated when I don't have to drive an hour and a half. Plus I can weld without worrying about my dad's painted floor.
Pretty much everywhere that there was metal to metal I found corrosion. This repair is where the bolt-on cab corner to fender connection is made.
The running boards are in great shape. It's the mounting channel that was full of dirt and moisture. Still haven't figured out what do do there.
Old 12-26-2017, 04:45 PM   #93
alanwoodieman
should not be too hard to remove the old and make two new ones. I will check my iron pile to see if I might have some off another board
Old 12-26-2017, 05:34 PM   #94
mhsprecher
mhsprecher's Avatar
Is that a one plane garage, er, hangar, to two? ;-)
mhsprecher is offline   Reply With Quote
Old 12-26-2017, 06:31 PM   #95
alanwoodieman
panelmark, wish mine was a dump, like yours!!
Old 12-26-2017, 07:39 PM   #96
cwh
cwh's Avatar
We're those rails a common way to mount running boards? I've looked a bit online but haven't seen anything similar.
Old 12-26-2017, 07:45 PM   #97
cwh
cwh's Avatar
Just one Supercub. But my dad has an addiction to model aircraft. He's got a bunch of large scale RC supercubs. The largest had a 12 foot wing span.
Old 12-26-2017, 08:14 PM   #98
Pat's 52
Pat's 52's Avatar
How do I open your photos?
Thank you!
Pat's 52 is offline   Reply With Quote
Old 12-27-2017, 12:35 PM   #99
cwh
cwh's Avatar
Thank you!
Is it some or all of the pictures your unable to see?
Old 12-29-2017, 11:26 AM   #100
Brad Hole
Brad Hole's Avatar
It's all looking great so far!
As far as the channel goes, I'll have to look to see if I have any sheet metal laying around, but I still have the die we made to remake the channels on my '47 1.5ton truck. I would imagine the channel is the same size. I'm not sure where you're at, but it may be possible to make and ship some to you.
Keep up the great work!
'47 79T Wrecker.
If you can't dazzle them with your brilliance,
baffle them with your bu*****t
Brad Hole is offline   Reply With Quote
