Is anyone making a relatively low compression (6:1) or less aluminum head ? of any style? Cast iron heads are getting to be too much for the back at my current state.-------thanks
The price may make your back feel better: http://www.millerhi-speedheads.com/products.html
How often are you removing heads? You could always use an engine hoist to remove them and move them to a work bench or at least chest high for optimal carrying.
Tod is making alluminum heads. Do a search on this forum for Tod.
Also Snyder has an aluminum head: http://www.snydersantiqueauto.com/th...mpression-head Here is a winfield aluminum head in 6:1 or 7:1 http://www.reds-headers.com/html/mod...ine_parts.html |
I have a 7-1 Thomas head on one model A that has a modified B engine. So far, I love it.
wow, just went through all those speed websites and I want my wife to ignore the debit card bill for a while
Peace & Grace, Eric Swanson 1931 Model A Pickup |
Snyders has a good selection.
It's not high compression that causes babbitt problems, it is detonation. I ran a 7.4:1 Cyclone head for years with no problems.
#13 |
Is there a stock looking aluminum head being made?
Also, do any of the heads mentioned above use stock sized plugs?
#14 |
#15 |
In the 60's and 70's I ran an original Thomas 8.25 aluminum head on an old worn out babbitt Model A engine.
Dwayne Helms here in Denver runs a 12.0 to 1 Cooke head on a babbitt engine. Last edited by Benson; 12-15-2017 at 03:18 PM. |
#16 |
So how did that work for you
Sent from my SM-J700T using Tapatalk |
#17 |
#18 |
the reason I specified 6:1 or less was to maybe reduce oil consumption. I really don't know but it would seem that a higher compression would tend to inhale more oil past the rings on the intake stroke-- that was my thought anyway.
#19 |
I would think tht would make no difference at all compression has nothing to do with the intake stroke while the valve is open
#20 |
Thanks for your reply. Any idea of how I go about buying one? Does Tod have a website?
