Old 12-06-2017, 10:02 PM   #1
Bleach
Bleach's Avatar
Default Trouble finding an air filter
I bought this air cleaner so I could use it on my 56 Fairlane after changing the manifold and carb. The air cleaner is supposedly from a late 50's or very earl 60's Ford product. It fits the Autolite 4100 carb perfectly. The problem is I can't find a filter for it. The filter I think I need should probably be:
Top - 10.39" O.D., 7.28" I.D
Bottom - 9.78" O.D, 7.28" I.D
possibly 3.22" tall.
I'm stumped. It's a Ford product. It shouldn't be that hard to find.
No catalog shows a filter that will fit. The closest one I found is from a Desoto. It fits but not perfectly.
I think the filter I need might be an AC A82C filter but I haven't found the dimensions for it.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Bleach is offline   Reply With Quote
Old 12-06-2017, 11:10 PM   #2
miker98038
miker98038's Avatar
Default Re: Trouble finding an air filter
Not sure this helps, and I wouldn’t pay this for NOS stuff that decomposes.
https://www.ebay.com/itm/VINTAGE-NOS...-/351677823294
Maybe an Edsel site has a replacement/solution that works.
miker98038 is offline   Reply With Quote
Old 12-06-2017, 11:21 PM   #3
Hot Rod Reverend
Hot Rod Reverend's Avatar
Yours looks very similar to mine...if you check my blog thread you can see quite a few photos. Want me to check my filter number?
Red Lion, Pennsylvania
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 12-07-2017, 04:02 AM   #4
KULTULZ
KULTULZ's Avatar
Question Re: Trouble finding an air filter
If the E-Bay info is correct, (and I do not find the PN on GOOGLE), A82C may be discontinued.
AC does have a current PN, A2882C for the period application. It gives no sizes.
Maybe contact AC?
https://www.acdelco.com/contact-us.html
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 12-07-2017, 07:53 AM   #5
scrapiron
Get a WIX paper catalog,, listings by size
scrapiron is offline   Reply With Quote
Old 12-07-2017, 09:36 PM   #6
Bleach
Bleach's Avatar
I think I asked you some time ago when your engine was still on a stand or was just installed. You had mentioned the height and it was shorter than mine.
Maybe contact AC?
I'll check with that new number.
I think that's how I found my Desoto filter.
I saw that. I wouldn't pay any kind of money for something that old that will end up as dust in my carb.
That's one of the listings where I found the part number.
Thanks everyone.
Old 12-07-2017, 09:44 PM   #7
Oldmics
Post up some pictures of that air filter from all angles along with the dimensions.
I have a 58 retractable currently in the shop and I believe its the same air cleaner.
Its a 332 engine. It uses a Purolater A40013 element.
The Purolator specs are below and are close to what you are asking for.
https://aftermarketfiltrationexperts...ternative-qty2
Perhaps its the same ?????
Oldmics
Oldmics is offline   Reply With Quote
Old 12-07-2017, 09:53 PM   #8
Bleach
Bleach's Avatar
I'll have to measure the filter housing when I get a chance.
Old 12-07-2017, 10:58 PM   #9
Ford Freak
Try Concours Ford Parts .
Ford Freak is offline   Reply With Quote
Old 12-07-2017, 11:30 PM   #10
Oldmics
Some shots of the air filter that I believe is the same as yours.
If you notice the lid is flush with the Purolotor element.
I believe your asking for that 3" height is a bit much as your lid sits a bit high.
I think the A40013 filter I am suggesting is correct.
Old 12-07-2017, 11:33 PM   #11
Oldmics
More Pics
Old 12-07-2017, 11:48 PM   #12
miker98038
miker98038's Avatar
Oldmics is probably on the right track. If not, I sent a pm. I’ve done this on similar filters. Not concours correct.
Old 12-08-2017, 12:46 AM   #13
KULTULZ
KULTULZ's Avatar
Oldmics
The PUROLATOR Filter A40013 crosses to the AC A2882C and FORD C3VY 9601-A.
http://www.airfilter-crossreference....ROLATOR/A40013
I tried earlier with the WIX dimensions catalog and found nothing with the height needed being listed. Maybe re-measure height?
Old 12-08-2017, 01:50 AM   #14
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Trouble finding an air filter
Yeah, I think you are correct also. I could find no referece to an element that tall.
Continued From Previous Thread- https://www.fordbarn.com/forum/showt...64#post1562664
Old 12-09-2017, 12:03 AM   #15
Bleach
Bleach's Avatar
I think I measured from the top of the recess of the air cleaner body down to the bottom inside and got nearly 3.25 inches.
I had actually bought the listed filter from NAPA back when I got the air cleaner and it was nearly an inch short. It was just hanging from the top rim with a sizable gap underneath.
Old 12-09-2017, 08:23 PM   #16
Bleach
Bleach's Avatar
Here's a few phots of the air cleaner and the inside measurement that shows that the filter needs to be over 3" tall.It's without a doubt a Ford produced air cleaner as it even has indentations to clear the usual bell crank and coil.
Old 12-09-2017, 08:56 PM   #17
KULTULZ
KULTULZ's Avatar
...ciphering...
Something doesn't ring with the rear shot.
EDIT-
Can you measure the assembly as it lays on a flat surface as to OD and HGT?
You said previously you had a FORD C3VY 9601-A element equivalent and it did not fully reach the bottom support?
You also said the seller repainted the cleaner? Do you see any signs of a previous color, black, blue, white or gold?
File Type: jpg ACL- 1958 On 1957 ECZ 9425-B - 57 4100.jpg (28.7 KB, 7 views)
Old 12-10-2017, 10:42 AM   #18
KULTULZ
KULTULZ's Avatar
Cool Re: Trouble finding an air filter
OK, I think I have found it. It was not in the 60/64 MPC (must have gone obsolete and was deleted from FINAL ISSUE).
Went back again to the 1967 READY REFERENCE CATALOG and it was listed there (I think). It only gave two dimensions, 9.74" OD and 3.13" H. It is listed only for 64 FORD and MERC.
Service PN C4AZ 9601-A. No reference found on GOOGLE. This must have been a very limited production run. Maybe explains why the guy got rid of it.
I think I read oldmic saying he had a period OSI Catalog. Maybe he can chase it and get an earlier PN.
I will keep looking.
Old 12-10-2017, 01:18 PM   #19
Oldmics
Green Ford Sales
http://www.greensalescompany.com/
shows that they have 6 of the C4AZ 9601-A in stock.
Have to call them for pricing
The OSI information that I have is from 1955 to 1961.
The 1964 MCR book crosses the service number (C4AZ 9601-A) to the actual part of C4AF9601B
Oldmics
Old 12-10-2017, 02:10 PM   #20
KULTULZ
KULTULZ's Avatar
Green Ford Sales
Oldmics
And have them throw a tape on it before buying...
So it is a CROSS REFERENCE CATALOG you have?
An OSI (Obsolete-Supersede-Interchange) Catalog will give SERVICE PN upgrades once they are out of the PRICE BOOK.
Nice to have either or both.
THANX Oldmics ...
