Old 11-27-2017, 10:33 PM   #1
gearheadbill
gearheadbill's Avatar
Default 1940 6 blade fan
On the 6 blade fan on my 40 3 alternating blades are 6.5 inches long and 3 are 5.5 inches long. Anybody know why?
gearheadbill is offline   Reply With Quote
Old 11-30-2017, 12:36 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 1940 6 blade fan
Reduce Noise? Provides easier access to work on front of engine?
Old 11-30-2017, 12:43 PM   #3
gearheadbill
Weren't most factory fans 4 bladed?
Old 11-30-2017, 12:50 PM   #4
deuce_roadster
deuce_roadster's Avatar
Every 39 deluxe-40 V8 fan I have seen had 6 blades.
Old 11-30-2017, 02:52 PM   #5
gearheadbill
Good to know...thanks
Old 11-30-2017, 05:47 PM   #6
Hal Beatty
Hal Beatty's Avatar
Yeah, that's a stock fan for a '40 Deluxe. Mine has the same thing...
Hal Beatty is offline   Reply With Quote
Old 11-30-2017, 08:57 PM   #7
swoopNZ
MEMBER EMERITUS
Could be something like the " propeller wash " effect.
Anybody out there with an aviation background.
swoopNZ is offline   Reply With Quote
Old 11-30-2017, 09:14 PM   #8
Binx
Probably more for sound reduction. The vortex from the leading blade tip will cause a pop when the next passes through it if they're the same size.
Lonnie
Binx is offline   Reply With Quote
Old 11-30-2017, 09:20 PM   #9
skidmarks
skidmarks's Avatar
Also 1941 and 40-41 pickups with V8
skidmarks is offline   Reply With Quote
Old 11-30-2017, 10:17 PM   #10
gearheadbill
Again, good to know. Thanks guys!
Old 12-01-2017, 09:42 PM   #11
drolston
drolston's Avatar
Advice for all fixers of crank mounted fan vehicles (39 - 41):
Before installing your fan, do a quick check by laying the fan face down on a flat table and see if all of the leading edges are touching the table. Then set it on the hub and check the that all of the trailing edges are the same height all across the length of all of the blades. Same thing for all of the leading edges. I installed a NOS six blade on my '41 without checking, and picked up a small but annoying vibration. Felt like the engine rotating assembly was out of balance. Drove the car without the fan and the vibration was gone. Adjusted the blades to level them out and all is smooth. The tip of one blade was about 1/2" low; another 1/4".
I put a crow bar in the center for leverage and was able to bend the blades up or down by hand, a little at a time.
Those fan blades bend easier than you might think. I will never again turn over the engine by pulling on the fan blades.
Old 12-01-2017, 09:58 PM   #12
mrtexas
mrtexas's Avatar
Likely set up that way so the fan doesn't get harmonic vibrations. With the blades spread evenly and the same length there is the possibility to get vibrations that get bigger and bigger that could break off the blades. If you look at the blades of a late model car they can be even more un-even to prevent the destructive vibrations. The analogy is pushing a kid on a swing. If you push at just the right time the kid goes higher and higher.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
