Old 11-03-2017, 06:16 PM   #21
ford38v8
ford38v8's Avatar
Default Re: accelerator pump Q..
Originally Posted by flatjack9 View Post
The accelerator pump gets it's fuel directly from the float bowl independent of the jets.
...and delivers through the same nozzles as is fed from the main jets. Don't confuse the man with partial facts that mean nothing to his question.
Alan
ford38v8 is online now   Reply With Quote
Old 11-03-2017, 10:19 PM   #22
flatjack9
flatjack9's Avatar
If we are talking about a Holley 94, you are wrong. The accelerator pump discharges through a "squirter" located between the 2 venturi. The main jets discharge through the two nozzles located in the middle of each venturi. The two systems are totally separate. I think you are causing the confusion.
Old 11-04-2017, 10:12 AM   #23
JSeery
JSeery's Avatar
Here's a diagram.
Old 11-04-2017, 10:50 AM   #24
scicala
scicala's Avatar
Correct. The Stromberg carbs discharge the pump shot out of the "J" nozzles, which also discharge fuel when the power valve opens.
Ford/Holley 94 type carbs have an independent accel pump circuit that gets the fuel supply from a hole in the bowl, and not the main jets.
Sal
scicala is offline   Reply With Quote
