Old 10-30-2017, 01:18 PM   #1
burner31
burner31's Avatar
Default Which plug do you run?
Champion W16Y on mine
Keith
Shawnee OK
'31 SW 160-B
Old 10-30-2017, 01:39 PM   #2
WHN
Default Re: Which plug do you run?
We have always used the Champion plug also. Never a problem. Enjoy.
Old 10-30-2017, 01:53 PM   #3
Patrick L.
Patrick L.'s Avatar
Autolite 3077
Old 10-30-2017, 02:08 PM   #4
AL in NY
AL in NY's Avatar
3X plugs run the best in my engine.
AL in NY
AL in NY is offline   Reply With Quote
Old 10-30-2017, 02:39 PM   #5
J Franklin
J Franklin's Avatar
3X also for me.
Old 10-30-2017, 03:16 PM   #6
smittykid
smittykid's Avatar
I run w16Y's as well-what gap setting do you use?
smittykid is offline   Reply With Quote
Old 10-30-2017, 03:29 PM   #7
WHN
Gap set at 35. Enjoy.
Old 10-30-2017, 03:31 PM   #8
JOHN CT
JOHN CT's Avatar
I've tried quite a few but 3x in my A,it's happy!! And so am I.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 10-30-2017, 03:44 PM   #9
Fullraceflathead
Fullraceflathead's Avatar
I'm running Firestones but only because they were in it when I bought it. They run fine so far I've driven maybe 1500 miles.
I'm going to put in the Repo Champion 3X's soon.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 10-30-2017, 04:40 PM   #10
duke36
The Champion #518 (W18) run nicely in h.comp. heads at .030/.032
Old 10-30-2017, 04:49 PM   #11
Big hammer
Originally Posted by duke36 View Post
the champion #518 (w18) run nicely in h.comp. Heads at .030/.032
x-2
get a bigger hammer tap done
Old 10-30-2017, 04:51 PM   #12
Y-Blockhead
Y-Blockhead's Avatar
Duke, since I installed my 5.5 head it seems to run rich with 3X (No other changes). Did you find the same? and that is why you run the W18's. I was thinking of trying the W18. Thanks
Old 10-30-2017, 05:04 PM   #13
duke36
See Larry Brumfield post of 6-29-10 for info. on plugs.
YBlock, our 5.5 w/ W18's (new no. 518) runs a nice tan color and the price is right per plug. We ran TT10's for awhile and the car likes the 518's with a Marvel carb. Note this is w/ FS zipper ignition which we're going to change back to modern points due to advance issues on hills and see how that works. Also, I use small amounts of lead substitute and ethanol stabilizer in gas (but not sure how much effect that has.).
Old 10-30-2017, 05:12 PM   #14
Y-Blockhead
Thanks for the info Duke
Old 10-30-2017, 05:27 PM   #15
duke36
Lot's of discussion/opinions about heat range, etc. We tried different plugs we had on hand to see what works for our set up, so others may have different experiences.
Old 10-30-2017, 05:43 PM   #16
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
ANYTHING with the right heat range & burns CLEAN!
There are NO "MAGIC" Spark plugs!
Driving with "GUSTO", helps to keep plugs running CLEAN.
LOOOONG idling sessions crap them up.
Bill Smooth
"THE ASSISTANT GURU OF STUFF"
Old 10-30-2017, 07:41 PM   #17
glenn in camino
glenn in camino's Avatar
I use restored Champion 3Xs in all my stock model As.
Old 10-30-2017, 09:15 PM   #18
RandyinUtah
37 years and 40000 miles on the same set of reproduction champion 3X and see no need to change.
RandyinUtah is offline   Reply With Quote
Old 10-31-2017, 05:10 AM   #19
Ed Saniewski
Ed Saniewski's Avatar
3X run the best for me.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 10-31-2017, 06:49 AM   #20
andyg
andyg's Avatar
Anything but new Champions.
andyg is offline   Reply With Quote
