Old 10-18-2017, 06:54 PM   #1
callbald
callbald's Avatar
Default radiator coolant bubbles
Is there anything other than a head gasket leak that would cause the coolant to bubble?. Engine was just rebuilt this past year.
callbald is offline   Reply With Quote
Old 10-18-2017, 06:58 PM   #2
JSeery
JSeery's Avatar
Default Re: radiator coolant bubbles
cracks. Was it pressure tested before the rebuild? I would re-torque the heads and if that doesn't help might try a coolant sealer.
Old 10-19-2017, 08:05 AM   #3
G.M.
I would add a large bottle of Barr's block sealer. Run the engine
and get it up near 200. Shut it down and let sit over night with
the cap on tight. I have seen lots of bubble problems, water out
the exhaust and it fixed 99% of the problems. I use the type with
copper flakes. G.M.
www.fordcollector.com
