Old 09-30-2017, 11:37 AM   #1
$um Fun
Default Claening a Tin Sided V8-60
I have tin sided flathead with over 40 years of caked on sludge and managed to remove over two coffee cans of sludge and want to get the block cleaned. I have been told that you don't want to hot tank the block with the tin sides and is like putting aluminum or brass in a hot tank.
Any ideas or methods that others have used to clean tin sided blocks would be helpful. This block is really filthy from not changing the oil.
$um Fun is offline   Reply With Quote
Old 09-30-2017, 11:57 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Claening a Tin Sided V8-60
Spray washer or hot tank with an aluminum safe detergent won´t be a problem...when the detergent get real caustic it becomes an issue with softer metals.
Old 09-30-2017, 04:10 PM   #3
40 Deluxe
I thought that the "tin" sides were actually stainless steel?!
Old 09-30-2017, 04:26 PM   #4
Dak Rat
Yes, side plates are stainless steel.
Dak Rat is offline   Reply With Quote
Old 09-30-2017, 06:41 PM   #5
KiWinUS
KiWinUS's Avatar
I have had several cooked in shake n bake cleaner with no issues
Old 05-03-2024, 08:14 PM   #6
Pete
I have hot tanked several with no problems.
Old 05-05-2024, 03:38 AM   #7
aussie merc
aussie merc's Avatar
if you can soak in diesel leave it in there for a week and it should wash out with soapy water
aussie merc is offline   Reply With Quote
