Old 09-24-2017, 10:07 AM   #1
Willit Stop
Willit Stop's Avatar
Default Cast brass heads
I went to a local car show a few weeks ago and briefly talked to the owner of a blue '36 roadster (I think he's a member here).His flatty was supercharged and had cast brass heads.I've never seen or heard of them before and must be rare.Does anyone know anything about these heads? Just curious.
Thanks.
Willit Stop is offline   Reply With Quote
Old 09-24-2017, 11:20 AM   #2
Russ/40
Russ/40's Avatar
Default Re: Cast brass heads
From the ones I've seen in photos over the years, they were used in marine applications.
Old 09-24-2017, 11:42 AM   #3
flatheadmurre
flatheadmurre's Avatar
Federal Mogul had some called termo-flow.
Sure look different...and cost an arm and a leg...
Old 09-24-2017, 11:43 AM   #4
RalphM
RalphM's Avatar
Bronze actually, made by federal mogul. Pretty rare birds nowadays.
RalphM is offline   Reply With Quote
Old 09-24-2017, 11:44 AM   #5
sidevalve8ba
sidevalve8ba's Avatar
Federal-Mogul made them. I believe they were a bronze alloy.
Cars are like potato chips, its hard to have just one.
sidevalve8ba is offline   Reply With Quote
Old 09-24-2017, 03:21 PM   #6
rotorwrench
rotorwrench's Avatar
The bad thing about the ones I've seen is that they have no water jacket. They look nice but would not be very practical. Some folks like the WOW factor more than something that works well. Race boat engines didn't use a radiator so they don't warm up the same as a car engine and don't really run for long periods. This is why the bronze heads are relatively rare.
Old 09-24-2017, 04:58 PM   #7
Willit Stop
I don't remember seeing fins.The top surface was flat...I think.
Old 09-24-2017, 05:43 PM   #8
Ol' Ron
Ol' Ron's Avatar
don't think they have any watr jackets??
Old 09-24-2017, 09:48 PM   #9
Flatout
Flatout's Avatar
I've seen iron heads polished and brass plated, but that over 60 years ago.
I have a couple sets of Federal Mogul heads that are are cast bronze with aluminum tops, and they do have water passages.
Flatout is offline   Reply With Quote
Old 09-26-2017, 08:22 PM   #10
v8fordman
v8fordman's Avatar
I believe you will find them on the McGee roadster...one of the most iconic hot rods ever. I saw it being restored at the SoCal Speed shop and I don't think there were any water outlets. That's been years ago and my memory isn't what it used to be.
v8fordman is offline   Reply With Quote
Old 09-26-2017, 10:55 PM   #11
RalphM
RalphM's Avatar
Picture I posted has the water outlets, and Sidevalves picture has the ports for the water outlets. But, it does not appear they go through the entire head surface. Only a way to get the coolant out of the block into the radiator.
