Old 09-23-2017, 02:50 AM   #1
Questus
Questus's Avatar
Default Clutch shaft rubbing?
Good morning from Germany,
GERTRUD: FORD A Canada of June 1928, no - no longer a multi-disc clutch!
ASK:
Clutch and pressure plate have to be new at Gertrud, I am in the engine extension forward!
Is it then, when the engine is out, possible to re-disengage the clutch shaft?
There is game, I mean: can I good rub in the bell housing ?? because of space to the chassis left and right?
Do you have any tipps for my work ?
regards from QUESTUS 10:00 o`clock AM North europe
Questus is offline   Reply With Quote
Old 09-23-2017, 02:57 AM   #2
Questus
Questus's Avatar
Default Re: Clutch shaft rubbing?
missing Picture inside
Old 09-23-2017, 07:32 AM   #3
wmws
I think you are asking if you take the engine out can you replace the clutch. Yes that is the easy way to get to the clutch but you can also do it with the engine in the car. In that case you would have to take the rear end out. I hope this helps.
wmws is offline   Reply With Quote
Old 09-23-2017, 07:52 AM   #4
Questus
Questus's Avatar
NO !!
clutch gabel shaft bushings - housing of that
hohnen in German / rub on bushings / bushings reamer
regards QUESTUS
Old 09-23-2017, 08:27 AM   #5
Glen in Hillman MI
Questus I think you are trying to replace the bushings? You can remove the housing and repair on your workbench.
Glen in Hillman MI is offline   Reply With Quote
Old 09-23-2017, 09:41 AM   #6
Marshall V. Daut
Questus:
Besitzen Sie schon dieses Buechlein?
Marshall
Marshall V. Daut is online now   Reply With Quote
Old 09-23-2017, 09:58 AM   #7
Marshall V. Daut
Skizze bezueglich der Kupplung anbei. Hilft das Ihnen?
Marshall
Last edited by Marshall V. Daut; 09-23-2017 at 11:30 AM. Reason: Forgot the second "p" in Kupplung
Old 09-23-2017, 11:24 AM   #8
Marshall V. Daut
Folks: When answering Questus, keep in mind that there is a seven hour time difference between Germany and Central Standard Time in the United States. If his replies are not forthcoming immediately, the time gap may come into play. I suspect most of his postings will be in the early AM hours for us, his late afternoon/evening time.
Marshall
Old 09-23-2017, 11:51 AM   #9
Railcarmover
I wish somebody would good rub my bellhousing..
Railcarmover is offline   Reply With Quote
Old 09-23-2017, 12:33 PM   #10
Bill G
Bill G's Avatar
I will take a stab at answering Questus:
If the engine is out, but the bell housing is still attached to the transmission, there might be some room to get a reamer in to ream the clutch shaft bushings, but I would recommend taking the bell housing off the transmission to do the bushings.
It is also very hard to remove the pin holding the clutch arm to the shaft with limited room when it is still mounted to the transmission. My recommendation is to take the bell housing out for that too if you haven't already removed the clutch arm.
When I reamed mine not long ago, the reamer was pretty long and so it might be a tight fit. However, if there is enough room to get the shaft out with the bell housing still on, then there is probably room for the reamer, but remember you have to ream bushings on both ends of the clutch shaft.
Also, if you take out the bell housing, you can also change the pedal shaft at the same time. Mine was badly worn.
Many years ago I went to Germany and tried to speak in German. It didn't work very well. People kept answering me in English.
I see Marshall has some German skills from his last two posts.
Alternatively, maybe at the same time the question is asked in English, you could also ask it in German, and anyone who wants can copy it and paste it in Google or some other translator which might also be a way to do it. Those translators are not perfect, but I think they go a long way to making the world a smaller place. (Just my own thinking)
I think it is great that this is an international forum!
Old 09-23-2017, 12:44 PM   #11
Marshall V. Daut
Fair enough:
1st post: "Do you already have this booklet?"
2nd post: "Diagram of the clutch attached. Does this help?"
Marshall
Old 09-23-2017, 12:51 PM   #12
Questus
Questus's Avatar
Default Re: Clutch shaft polishing / bear off ?
Thank you for the replies
Please excuse the not perfect technical English.
Nice, when the bell housing Railcarmover enjoy!
The drawings help a lot, but I have a very good selection of original technical documents in English and dutch, but I can't find anywhere the bushings of the shaft.
The parts are as helpful lists at Mike`s Georgia.
regards Questus
@ Bill the best answer I have, I write in the future in German
Old 09-23-2017, 12:54 PM   #13
Marshall V. Daut
Your English is VERY good, Questus, far better than most high school "graduates" in this country, who only speak in text-ese. Keep posting!
Marshall
Old 09-23-2017, 02:19 PM   #14
1955cj5
1955cj5's Avatar
regards Questus
Is this what you are looking for??
https://www.brattons.com/june-29-31-...shaft-set.html
The link has helpful drawings...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 09-23-2017, 06:09 PM   #15
Railcarmover
regards Questus
I've got my problems with German,you with American.Maybe we should get a bellhousing together..
Old 09-24-2017, 02:06 AM   #16
Questus
Questus's Avatar
@ 1955 cj5
thanks !! that are very good informations/pics
( but Gertrud is early June 28 -- but the same principle!)
@ Railcarmover
fine ! early VW1302 of 1971 !! I have the same, but with a Little Change
(engine Porsche 3.000 ccm 204 PS 273 Nm @ BOSCH roll - to check the realpower)
Old 09-24-2017, 10:31 AM   #17
Railcarmover
@ 1955 cj5
@ Railcarmover
My 67 has a 1600sp converted to doghouse cooling,counterbalanced crank,balanced rods and pistons,w100 cam,hand ported and deshrouded heads,drilled and tapped for full flow filtration,019 distributor,H30/31 carb,type 3 starter,alternator..50hp of smooth,drive anywhere reliability
3000cc Porsche power in a 1302? nice...my car wont pull the hat off your head..yours would set it on fire..
