Old 09-22-2017, 07:57 AM   #1
barkleydave
barkleydave's Avatar
Default Oil fill pipe leak
I have been chasing a pesky oil leak and thanks to James at DreamWorks, (I stopped by on a recent tour) he spotted the problem right away. The pipe is not snug enough and it is weeping oil at the base of pipe and block.
Any ideas how to seal it tighter?
Got up to 5,600 ft on the Blue Ridge. The Ole truck did a good job... thanks to a 5:1 head and cast iron brake drums!
We had planned on going to B. Terry's but a family situation cut our tour short and we had to load up and head back to KY.
Thanks
barkleydave is offline   Reply With Quote
Old 09-22-2017, 08:32 AM   #2
Glen in Hillman MI
Default Re: Oil fill pipe leak
Pull the breather tube from the block and clean oil off the tube and the hole in the block. (Gas?). Then run a small bead of permatex2 around the lower portion of the tube and push back into the block. In a couple of days, it should be secure.
Glen in Hillman MI is offline   Reply With Quote
Old 09-22-2017, 09:41 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
It "may" be just mist from the cap vents, running down. Very normal. Some put a sock over it, for long trips. "Sometimes" it'll blow down behind the starter & look like a rear main leak!---And you'll say, "OH SHIT, OH DEAR"!!!
Bill Dripper
"THE ASSISTANT GURU OF STUFF"
Old 09-22-2017, 10:38 AM   #4
glenn in camino
glenn in camino's Avatar
The sock might create back pressure and leaking from the rear main.
Old 09-22-2017, 01:12 PM   #5
BILL WILLIAMSON
NOT EVEN!! Just use it over the CAP/TUBE. Just DON'T use your Wifes' CUTE socks!!!
Bill W.
Old 09-22-2017, 02:02 PM   #6
CarlG
CarlG's Avatar
My oil fill pipe was so tight that I had to drive it out with a socket from the back side.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-22-2017, 07:32 PM   #7
Ian in Mississauga
For a permanent fix tin it with soft solder (lead/tin) then tap it in.
Ian in Mississauga is offline   Reply With Quote
Old 09-23-2017, 12:07 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
use a pipe expander
Old 09-23-2017, 02:55 AM   #9
Synchro909
Synchro909's Avatar
I used the tin with soft solder technique with success.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 09-23-2017, 03:37 AM   #10
Dollar Bill
Dollar Bill's Avatar
I fixed mine with Permatex® Form-A-Gasket® No. 1 Sealant
Description: Fast-drying, hard-setting sealant designed for sealing rigid materials and flanges, or patching holes and joints where permanent assembly is desired. Temperature range -65°F to 400°F; resists common shop fluids and fuels.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 09-23-2017, 07:01 AM   #11
marty in Ohio
marty in Ohio's Avatar
Mine was loose so I took it off and gently tapped the inside of the tube with a drift pin. This made a dimple on the inside of the tube and a pimple on the outside. Put a little sealer on it and tapped it back into the block.
Worked like a charm.
Marty
marty in Ohio is offline   Reply With Quote
Old 09-23-2017, 07:06 AM   #12
barkleydave
Thanks guys great suggestions.
