Old 09-15-2017, 09:51 AM   #1
Bob NH
Bob NH's Avatar
Default Correct plugs ?
Probably a dumb question, but what Champion plugs for a 1940 ? Not sure if that is my trouble or not but I have changed out the coil,condenser and distributor,good inner caps and plug wires so far and still not able to over come a skip when regular cruising on flat road. Car starts,idles smooth, plenty of power but has this annoying "hitching" going down the road. Where to now guys ?
Bob NH is offline   Reply With Quote
Old 09-15-2017, 10:19 AM   #2
oldford2
oldford2's Avatar
Default Re: Correct plugs ?
"idles smooth" You are running on the idle jets
"Plenty of power" You are running on the accelerator pump and power valve
""hitching" you are running on your main jets
Save your money and remove and clean the main jets. Easy fix. Just takes a spec of dirt to clog a jet. Check the bowl for sediment/dirt while you have the top off
John
oldford2 is offline   Reply With Quote
Old 09-15-2017, 10:24 AM   #3
tubman
tubman's Avatar
I agree that this is probably a fuel problem. I had the same thing happen to me with a Corvette; it ran beautifully except for an occasional "hitch" (good term for it, by the way) cruising down the road. It turned out to be the carburetor.
Old 09-15-2017, 01:21 PM   #4
Bob NH
Bob NH's Avatar
I would never have believed it to be carburetor trouble ? It just seemed like it would be electrical, I'll give it a shot fella's and see how it goes and thanks for the replies.
Old 09-15-2017, 06:15 PM   #5
ford38v8
ford38v8's Avatar
First rule about ignition problems is that the problem is fuel.
First rule about fuel problems is ...
Alan
