Old 09-09-2017, 11:56 PM   #141
1stford
1stford's Avatar
Default Re: 1936 Truck restoration
Yeah I had a bunch of pictures on photo bucket and they want to charge me to have them up. I'm going to try and go back and post the pictures that are missing. I was able to get almost all of the interior finished, hope to finish it tomorrow. Also got the horn finished and put on.
I'm not sure why the pictures are sideways but if you click on them they appear to be correct.
1stford is offline   Reply With Quote
Old 09-12-2017, 08:29 PM   #142
flat-v8
flat-v8's Avatar
Wowee absolutely beautiful!
flat-v8 is offline   Reply With Quote
Old 09-13-2017, 12:20 PM   #143
1stford
1stford's Avatar
Could I get a couple ideas as to why the light switch would be hard to turn? I installed it and when the light switch is not on it turns smooth. When I put that on it turns easily for a few times and then gets where it won't go.
Also, is the correct way 1 to right and 2 clicks to the left?
Thanks in advance.
Old 09-14-2017, 10:09 PM   #144
Lawson Cox
Lawson Cox's Avatar
Originally Posted by FlatheadTed View Post
Here's a few exhaust shots ,the trucks the same as a car, Nice truck to ,Ted
The tail pipe on the pickup is 4" shorter than the pass car. I still need to perform a briss on mine. LOL
Old 09-15-2017, 10:28 PM   #145
1stford
1stford's Avatar
I'm getting to the end and one of my last things is an exhaust system. I have no parts but want a factory look I'm hoping for recommendations based on experience. Couple thoughts I've had I'd buy a muffler from Roy Nacewitz and have exhaust shop build The rest. Or I've seen a kit from Waldron exhaust that looks nice. Any ideas?
Thanks.
Old 09-15-2017, 11:20 PM   #146
mrtexas
mrtexas's Avatar
Thanks.
Wiring for these old girls is primitive. All you have is head/brake/tail lights, charging, and ignition switch. Later wiring harness should work just fine. If you can read a wiring diagram you should be OK. How about mounting the voltage regulator under the dash out of sight?
I like the paint job! Just sold a 28 pu painted dark green. Ignore the originality pubahs telling you the running boards aren't correct and should be black. If you like them body color keep em like that.
I've bought two stainless exhaust systems from Waldron. The 36 woodie one fit pretty good although they had to make a 2nd crossover pipe for me as a muffler shop had to add 2 inches to get it to fit. Charged just for materials. The 41 woodie stainless exhaust required me modifying every piece to get it to fit. I cut and tacked and had a friend tig with stainless. If you know the exhaust shop is very good with antique cars that sounds like a deal to me or if you are going with dual exhaust.
Your light switch should be one to the left for parking lights and one to the right for headlights if I remember from my 36 correctly. Do you have an original light switch, the bulb looking thingy at the end of the steering column? The repop ones are crap and should be avoided. Only other problem with light switch could be bent light switch rod.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 09-15-2017, 11:35 PM   #147
mrtexas
mrtexas's Avatar
Originally Posted by V8COOPMAN View Post
I'd get in touch with Tyree. The mods are all "do-able" to a stock harness. I'm lovin' this truck! DD
I asked Tyree to make a 36 harness with turn signals and just one harness instead of several. He said no.
Old 09-16-2017, 06:35 AM   #148
1stford
1stford's Avatar
Thanks for the feedback.
Old 09-20-2017, 06:49 PM   #149
1stford
1stford's Avatar
Would anyone mind to post a picture of the glove box Spring installed for a 36 truck?
Thanks.
Old 09-20-2017, 08:18 PM   #150
KDL
KDL's Avatar
Looking good.
KDL is online now   Reply With Quote
Old 09-20-2017, 09:21 PM   #151
VeryTangled
VeryTangled's Avatar
36 passenger glove box photos here
https://www.fordbarn.com/forum/showt...4971&showall=1
-Jeff H
Old 09-22-2017, 11:30 AM   #152
1stford
1stford's Avatar
I thought I'd post some pictures of my progress. I now have electricity rolling so its about ready to be started.
Old 09-22-2017, 12:52 PM   #153
Don Rogers
Don Rogers's Avatar
There is no spring on a 36 glove box door. It's held closed by a clip.
Don Rogers is offline   Reply With Quote
Old 09-22-2017, 01:48 PM   #154
Don Rogers
Don Rogers's Avatar
Here's a photo
Old 09-22-2017, 03:43 PM   #155
1stford
1stford's Avatar
Thanks Don. Had a sandwich bag labeled "glove box spring" and thought it went there.
Old 09-22-2017, 06:19 PM   #156
38bill
38bill's Avatar
That green just really looks great on that truck. Are you going with WWW's?
38bill is offline   Reply With Quote
Old 09-22-2017, 09:12 PM   #157
1stford
1stford's Avatar
I do not know what that means?
Old 09-22-2017, 09:58 PM   #158
38bill
38bill's Avatar
Wide White Walls
Old 09-23-2017, 12:08 AM   #159
1stford
1stford's Avatar
They are 6.50
Old 09-23-2017, 08:46 AM   #160
Jeff/Illinois
Jeff/Illinois's Avatar
We're running 6.50/16's on our '36 PU I like them.
Have a 6.00/16 for a spare tire the 6.50 would be a tighter fit there.
